clock spring
Old Mar 16, 2003 | 07:07 PM
Harmening's Avatar
Harmening
Question clock spring
I have a 1994 F-150. My cruise and horn no longer work. I'm looking at maybe changing my clock spring myself, but first I need to know exactly where it is located. If someone could give me at least a rough idea, it would be appreciated.
Old Mar 16, 2003 | 07:19 PM
steve83's Avatar
steve83
clock spring
It's between the steering wheel & the steering column. You can see a pic of it in this album, but it's not installed. You don't have to worry about the airbag - it's perfectly safe to work on. The first connector you unhook shorts the airbag safe, and NO electric power is stored anywhere in the airbag system. Once you get the steering wheel pulled off, it'll be obvious how to pull the clock spring.
