Gear Ratio
That formula will give the RPM at any speed, with any ratio and tire size. When you are figuring the final drive, multiply the axle ratio X the ratio of the top gear. With a non-OD trans, top gear will be 1:1 (direct), while an OD trans will have a lower than 1:1 ratio (IE: .76:1).
Also, remember that as tire diameter goes up, you'll need a little higher "target" RPM. Example, going from a 33" tire to a 35" tire, ideally you would want to have 200-300 more RPM to overcome the higher rolling resistance of the taller tires.
https://www.ford-trucks.com/forums/9...ml#post8830072
https://www.ford-trucks.com/forums/1...l#post10112981
Here is where someone says the calculator is:
https://www.ford-trucks.com/forums/7...ml#post6756082
Another linked one in the same thread:
Novak Conversions - Gearing & Gearing Math for Jeeps
And one that does the math for you:
Automotive Calculators offer to you by Ford Trucks Enthusiasts | www.ford-trucks.com
On a side note, Rogue, I am starting to admire your patience.
simple search revealed that you have answered this question multiple times, even twice today...
