? About Drop Pitman Arms
Old Mar 19, 2011 | 11:13 PM
79 shortbed lover's Avatar
79 shortbed lover
What is the differance between the one for a 4" and a 6" lift? What else is needed to change from the 4 to a 6" lift?
Old Mar 20, 2011 | 10:43 AM
HIO Silver's Avatar
HIO Silver
2 inches!! LOL..
Do you mean differences in parts? If so...
With a 4-inch, typically you can keep the same brake lines, shocks, and change to the corrected C-bushings. However with a 6-inch, brake lines and shocks will end up being too short and, personally, I'd recommend including radius arm drop-down brackets and a trackbar drop bracket.
Other than that, the coils and leafs/blocks will be the only difference in providing the extra 2 inches of height.
Old Mar 20, 2011 | 02:52 PM
79 shortbed lover
Originally Posted by HIO Silver
2 inches!! LOL..
I have the 4" already with the brake lines and the track bar bracket just wandering if the drop pitman is the same or if i need to get a new one?
Old Mar 20, 2011 | 02:58 PM
earthquake68's Avatar
earthquake68
I'm pretty sure I used a 4" dropped pitman arm on a 6" kit. But that was a 3/4 ton. A whole different animal. I think you should be ok with the pitman arm you have.
White76
Dec 15, 2021 12:51 PM
gentrykm
Oct 31, 2014 06:24 AM
Shwan_89HD
51
Mar 3, 2012 11:39 AM
2006HarleyF250
Dec 21, 2005 01:15 PM
