6.9l IP removal tips?
Old Mar 19, 2011 | 07:20 PM
Tom Norton's Avatar
Tom Norton
hi all and thanks for all the tips previously as I was trying to get my '86 6.9 to light off.
I did a compression test and way low in the front cylinders to the back still low but not much the back 2 holes.
anyway off comes the heads and I'd appreciate tips on pulling the IP with as least later on correction as possible.
thaks to all that chime in.
Tom with the layed-down 6.9.
Old Mar 19, 2011 | 08:05 PM
snaponprofile's Avatar
snaponprofile
Don't try to take the injector lines off the ip, just remove the ip with the lines connected to it. The rest is common sense.
Old Mar 19, 2011 | 09:08 PM
ihateminimumwage's Avatar
ihateminimumwage
Scribe a line of where your timing is! Use a razor, not a marker (I learned the hard way)
Leave the injector lines on as stated before, just disconnect them from the injectors. I removed the line from the fuel filter to the IP though, just to get it easier to maneuver out. Also easier if you remove the bolts that hold the throttle cable to the intake to give the IP any easier route out. Oh, and don't remove the gear cover.
Take your time and use your head, it's an easy procedure after the first time, same with the heads.
Old Mar 19, 2011 | 09:15 PM
snaponprofile
I took the ip hard line out as well, remove the throttle cable and unbolt the bracket from the intake manifold as well. That will make it easier to get the new one in.
Tom Norton
Mar 11, 2011 01:31 AM
Tom Norton
Feb 15, 2011 10:01 AM
Tom Norton
Jan 28, 2011 09:59 PM
mudguts
Jan 20, 2011 07:44 PM
f100guy
Apr 15, 2007 01:22 PM
