2000 explorer ebrake pedal
Old Mar 19, 2011 | 06:53 PM
VRC9170's Avatar
VRC9170
Does anybody have an exploded diagram of the ebrake pedal. I am trying to find why it does not release completely unless I pull it by hand as I hold the release lever. It does release about 1/2 to 2/3 of the way itself.
Thanks
Bob Bates, Surrey
Old Mar 21, 2011 | 11:26 AM
Mikeymoe's Avatar
Mikeymoe
Bob,
have you checked the emergency brakes lately? they contain springs that would have an impact on the E-brake pedal not returning. i had the same issue- i recently replaced mine as the shoes had no material left, and were neglected for some time. i also replaced the spring kit as well. better than new....
Old Mar 21, 2011 | 08:56 PM
steve(ill)'s Avatar
steve(ill)
cable going to the rear end sticks / corroded in the holder bracket... springs inside the rear wheel brakes rusted, shoes corroded, failed... all will cause the problem.
Old Mar 21, 2011 | 09:18 PM
VRC9170's Avatar
VRC9170
You are going to really laugh at this. My wife spent 1200 bucks doing all disk brakes and rotors at a shop up north and the shop said he fixed the park brake. The pads, springs are all supposed to be new.
I was 800 miles south at the time and ,of course, the mechanic was not an FTE member..
I do believe you are correct about the release sticking. Also, the mechanic had the adjuster set out very tight. I had the ebrake on a couple of days ago and it only partly released. I found out after nearly burning my hand touching the wheel later. I just set the adjustment on that side so loose that it will not hold if the brake is set.
Bob
