Okay, havent done this one yet, looks to be two bolts for the carrier, 4 for the drive shaft, some form of alignment mark for the shaft, but what about the boot, can I get new hose clamps for this, or they reusable?, Do I need to press the shaft out, or will it just come out? EIther way, looks like fun..
Thank you sir.. just tried to get the bearing off... no go, put a bearing puller on it.. yeah, busted.. getting ready to head to work and use the press with the bearing puller.. should have done this at lunch...
IT is of my opinion that if its the same subject, and you need help, it is not a hijack..you may have just asked a question someone else in wondering..
its not bad at all. take the drive shaft off. i used a puller and pulled the bearing off. then to reinstall use a piece of pipe and mallet to get the new beaing on. i posted a thread a while back about the 2 different sizes. when you go to get the part they have two differnt sizes. ill try to find the thread and repost for you
