Stats: 04' SD 250, 6.0, 189,000 miles, egr delete, 4x4 Recent repairs: Cab lift to install Y pipe to turbo, egr delete, new starter
Problem: While driving on a rough dirt road the truck seemed like it was running out of fuel- happened 3 times in about 5 minutes. I would stop, put in park, turn key, truck would start right up. 2 hours later, returning home, the truck went dead. Would turn over but not start. Batteries are fully charged, engine would spin over fast but no start. After 3 hrs in the middle of no where I sprayed some ether in the air intake. Still spin over- no start. No try to start or nothing. I am at a loss. One friend said I have a broke camshaft just on information which has me sick. Any help would be greatly appreciated.
from what i understand you should never spray starting fluid in the intake on these new diesels, a friend of mine let his duramax run out of fuel and his father in law sprayed some in his intake and the truck over-reved when it started and threw a rod...
I wouldnt think that your problems are from a broken camshaft. It maybe hpo or ficm related maybe something rattled loose on the rough dirt road check the connections to the ficm box ontop of the driver side valve cover.
you could also try to unplug the icp and see if it starts
sence 03 I have seen exactly one broken crankshaft *caused by a case of dumba$$) and the only cam failers I have seen were from failed lifters.
IMO its not a cam or crank issue however ymmv.
Just got home from work, I disconnected the air cooler to the intake and it just about sucked my hand in, checked the exhaust and it pushed my hand away. Guess the cam is ok. I am going to check the connections to the ficm and icp. Be back as soon as I have some answers. THANKS YOU GUYS
Just got the ficm off, the middle connection just fell off. I am going to use the tech info and check the ficm for DC voltage after I charge the batteries to 100%.
Reason: changed procedure
that middle connection was probably it check all the pins in the connectors make shure none are bent and make shure they are plugged in fulley.
I tested my ficm voltage, 27.2 VDC with the key turn on. Can someone tell me what my next steps are? 1) look for cracked solder, 2) send for repair, 3) buy new ficm?
My truck wouldn't start on cold starts sometimes. Wouldn't start the past couple of days. Instead of towing it back down to my mechanic (again), thought I would tinker with it. Figured it was a FICM from reading. Seems to be a common problem. I noticed that my FICM was only connected by the 2 nuts on front. Nothing in back and it was quite wobbly. My middle connection just fell off as well. I went ahead and took it out, touched up the solder joints as recommended by taking it all apart. The 4 resistors that didn't look like they were making a good connection. I didn't see any solder on them. Fixed that. Put it back together, installed it, zipped tied the back down and WALLA, she started right up today!!!! Took be about 30-40 minutes to take apart and resolder joints. I pretty good with electronics so it may take a bit longer if you are not.
Here is the link I used and it worked great. All credit to the writer and thanks! shows all pictures.
