64 F100 project
Old Mar 18, 2011 | 03:54 PM
Hadrian86's Avatar
Hadrian86
64 F100 project
I'm still fairly new here, been working on my 64 for awhile. Was wondering if anyone could decode some numbers on it for me? Would really appreciate it. Pretty sure its all original,
F10CE470483
114 J F100 E81 A 11
5000 135 3800 22
Old Mar 18, 2011 | 06:54 PM
kjvforme's Avatar
kjvforme
F10CE470483
114 J F100 E81 A 11
5000 135 3800 22
F10= F100 2 wd
C= 292 CID, 1 barrel carb
E= Manufactured in the Manawah, NJ plant
470483= Built in October 1963
114= wheelbase in inches
J= Rangoon Red exterior color
F100=Same as above
E81: E = Red Crush Vinyl & Red Check Stripe Woven Plastic // 81 = 81B Custom Cab.
A= Three speed light duty manual transmission
11 = Ford 9" Rear Axle / 3.70-1 / non Limited Slip / 3300 lb. Rear Axle Capacity
5000= GVW
135=Horsepower on the engine
3800= RPM
22=Charlotte, North Carolina Districtr Sales Office (who the dealership ordered the truck from) No additional numbers behind the DSO most likely means it was bought off the lot.
Old Mar 18, 2011 | 07:45 PM
Hadrian86's Avatar
Hadrian86
Thanks a lot, Good to know its a NC truck (where I live).
Old Mar 25, 2011 | 02:52 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C = 292 2V. No 1V carbs on V8's.
E = Mahwah NJ Assembly Plant.
470,483 = 1964, assembled November 1963 (November 1963 serial numbers: 470,000-479,999)
F100 2WD, 5,000 lbs. GVWR
A = Ford type 3.03 3 Speed Manual Medium Duty all Syncromesh Transmission (Light Duty: I-6 only).
135 Certified net HP @ 3800 RPM.
64f100sixcylinder
Feb 11, 2014 12:39 PM
73f100rangerguy
Jun 11, 2011 04:30 PM
irb
New Member Introductions
Jan 31, 2008 09:45 PM
jowilker
Jul 21, 2002 12:01 AM
