Need help with power steering
Old Mar 17, 2011 | 11:02 PM
BrandonT71's Avatar
BrandonT71
I am looking for some advice on how to diagnose my power steering problem. Shortly after buying the truck last year I replaced upper and lower ball joints, inner and outer tie rods and did the front brakes. All were in need of repair. After the repairs were complete I had the front end aligned. After the work was done the steering was much improved from slop and clunk of the worn out front end. Now 6 months down the road the steering is getting progressively stiffer and there is a groaning noise when going around corners. I plan to flush the PS fluid soon. My question is how do properly diagnose a bad pump or bad steering box. Not sure if either is causing the problem. Any advice greatly appreciated.
Thanks, Brandon
Old Mar 17, 2011 | 11:07 PM
snakedoc's Avatar
snakedoc
the pump uses aft. i would flush it out and put new in and see if that helped. if the gear box is lose you can tighten the nut on top it will help.
Old Mar 17, 2011 | 11:29 PM
Bonanza35's Avatar
Bonanza35
Cool
X2 , If you or somebody used power steering fuild you could hurt the
pump. It takes ATF. Flush that and see if it helps. Also is it low, that will cause your problem to.
Old Mar 18, 2011 | 12:19 AM
clintbonnie's Avatar
clintbonnie
Suggest you use Mobil 1 AFT mercon when you flush and replace the fluid in the pump.. great stuff..
Old Mar 18, 2011 | 09:09 AM
Fat Diesel's Avatar
Fat Diesel
Also put as much air as you safely can in the front tires.
Old Mar 18, 2011 | 12:05 PM
BrandonT71's Avatar
BrandonT71
Fluid levels are full, will flush maybe Sunday, if I get time. If that doesn't help, and steering is still stiff and groans going around corners, how would I diagnose whether its the pump or gear box causing the problem. Thanks.
Old Mar 18, 2011 | 05:10 PM
SteveH-CO's Avatar
SteveH-CO
Often the pump is noisy itself. Have someone turn the wheels back and forth in your driveway while you listen to the pump with a stethoscope (or long stick held up to your ear). I've never heard a steering box moan - only pumps. I'd vote for the pump.
brandon74
Apr 21, 2012 12:03 PM
KING
Jun 23, 2011 05:36 PM
SSSimon
Sep 29, 2010 04:51 AM
jspringator
Jul 17, 2007 03:10 PM
TimV
Feb 27, 2004 08:53 PM
