I love my new radiator an electric fan
#76
As far as buss panels are concerned do not forget that you can build your own. I used a 8 inch long piece of thin sheet steel 1 1/2 inches wide. I drilled 4 holes in it and mounted a 120 amp fuse across the first two holes, set off by rubber stoppers from harbor freight. Power goes from my 3G alternator to terminal 1, across the fuse and then provides hot output to the battery and the other terminals. Each rubber stopper looks like a motor mount but miniature in size. Then from post 2 to 3 and 3 to 4 I built a wire loom with 12g wire and ring connectors, soldered, so the entire assembly is in the 12 to 13.5V range depending on your alternator's output when the engine is running. Finally I mounted a plastic box that covered the terminal buss to prevent it's accidental shorting out by tools should you be klutsy while working in the engine compartment. This type of setup is common on aircraft and is where I gleaned the technique. You can run your alternator gauge off of these terminals and it is a cheap alternative to expensive fuse blocks and similar terminals, too.
#77
Josh
#78
wiring and relays
do you have any parts info on the relays and wiring, I p/u a fan assembly from a 4.6l ford, looks like the same fan, robbed as much of wiring from the car I could, has no relays but a 10amp fuse the was on the radiator core support
I did review your thread, just need a clearer idea on wiring and relays
thanks!!
thanks!!
#80
#81
#82
#84
Just to add another wiring idea, this is how I have mine. Low comes on with a $17.99 temp controller from Autozone, and high is manually turned on when the A/C is on. If I ever needed the high setting without the kicking the compressor on I could just disconnect the wires at the compressor to keep it from coming on. But I, like most people who have done this upgrade, have never needed to use the high setting for keeping the truck cool.
[/QUOTE]
[/QUOTE]
#86
Here you go. If the link below doesn't work the part number is 733653.
Compressor Works/Electric Fan Thermostat (733653) | 1977 Ford F100 1/2 ton P/U 2WD 8 Cylinders G 5.0L 2BL OHV | AutoZone.com
#87
Excelent wire diagrams on this link.
Mark VIII & SPAL V3
read post 28 and post 33 on page 2. one diagram shows how to have RGB Light LED
indicator when fans are on for high low and AC
Mark VIII & SPAL V3
#88
#90
The Taurus fan is smaller.
Josh
