6637 questions
Old Mar 17, 2011 | 07:28 PM
wrdabney's Avatar
wrdabney
6637 questions
I just got done installing the 6637 kit from riffraff and I have a couple of questions.
1. In some pictures I've seen of the kits installed it looks like the whole battery box/intake from grill has been removed. Is this ok to do and if so how do you secure the battery in place?
2. In the picture, it looks like the filter goes completely underneath the rail where the hood closes, mine sticks up about 1" above this rail. Is this ok?
Old Mar 17, 2011 | 07:34 PM
Krawler62's Avatar
Krawler62
I had to cut away most of the stock air box on the fender side. It will then fit underneath the lip.
Old Mar 17, 2011 | 07:37 PM
locknload223's Avatar
locknload223
I think most leave the lower portion of the box installed, I did. To get the filter to lay low, I trimmed some plastic from the bottom of the box to make more room for the filter. Once you do this, loosen the clamp at the CCV coupler and twist the intake hose/filter until the filter lies at the lowest position. You'll see what I mean when you get into it.
Old Mar 17, 2011 | 07:56 PM
snakedoc's Avatar
snakedoc
i took it all out and made a tray to hold the battery. you can get a tray out of a van that will fit.
Old Mar 17, 2011 | 08:55 PM
wrdabney's Avatar
wrdabney
Thanks guys. Snakedoc, do you happen to know what model van you got it out of? Maybe I could find one on eBay.
Old Mar 17, 2011 | 09:13 PM
snakedoc's Avatar
snakedoc
i just made mine out of a sheet of aluminum. i think the same years as our trucks.
cameeks
Sep 7, 2012 08:28 PM
TheBludgeon
Oct 15, 2011 01:01 PM
A/Ox4
May 15, 2011 07:48 PM
daner01
40
Nov 19, 2010 10:07 PM
john8403
Nov 15, 2009 10:25 PM
