rack and pinion
Old Mar 16, 2003 | 01:38 PM
Frank3412's Avatar
Frank3412
rack and pinion
I have a 37 ford pickup can i put a manual rack and pinion steering box using the original straight front axle.
Thanks Frank
Old Mar 17, 2003 | 07:55 AM
GreatNorthWoods's Avatar
GreatNorthWoods
rack and pinion
Frank,
I know it's been done, but it's not a good idea. A rack and pinion was designed to be mounted in a stationary position. If you mount it on the axle, it moves up and down with the suspension and this movement will result in bump steer. Bump steer is where the steering wheel moves back and forth when you go over bumps...
Old Mar 17, 2003 | 08:29 AM
BELLM's Avatar
BELLM
rack and pinion
Sell it to me and you won't have to worry about it!! Been a long time since I had my 37 but maybe can adapt later box. Is it stock or hot rod?
Old Mar 17, 2003 | 11:10 AM
Frank3412's Avatar
Frank3412
rack and pinion
Eddie
The 37 is pretty much stock dual carbs original flathead v8 bored 40 over mallory ignition stock rear and tranny has a new pro picks bed interior from 86 ford taurus iditit tilt steering column i am in the process of painting it now has over sized tires I maybe selling it this summer. I really dont like the way it handles Ive driven it about 600 miles it has front and rear sway bars but that steering bow has got to go
Frank
Old Mar 17, 2003 | 11:30 AM
ferguson777's Avatar
ferguson777
rack and pinion
I undersatnd how the R&P unit would have to be mounted solidly to the straight axle but how the heck would you connect the R&P unit to the steering column with all that movement in the R&P going up and down over every bump?
Old Mar 17, 2003 | 02:17 PM
Frank3412's Avatar
Frank3412
rack and pinion
I dont know if it would work either do you know of a inexpensive steering box to put in it
Frank
cwest73
Nov 3, 2010 09:29 AM
dlibson
1983 - 2012 Ranger & B-Series
Apr 16, 2010 09:38 PM
rv21350
Nov 28, 2001 05:43 PM
ranger pat
May 23, 2001 05:09 PM
