New update released !!
Old Mar 17, 2011 | 06:10 PM
CDNMuddawg's Avatar
CDNMuddawg
Recieved a call from my service advisor today that the newest update is out which should cure the CEL and other transmission problems. Anybody else heard about this ?
Old Mar 17, 2011 | 06:42 PM
mr.windows's Avatar
mr.windows
Is this for transmission issues or does it fix all us guys with the P164A codes?
Old Mar 17, 2011 | 08:46 PM
Shepardsonp's Avatar
Shepardsonp
If you can give some more details, I am picking up my new 2011 next week and want to make sure this update is added BEFORE I take delivery. Thanks for sharing !
Old Mar 17, 2011 | 08:49 PM
frt2599's Avatar
frt2599
Have not heard but hope it's true... Keep us updated..
Old Mar 18, 2011 | 11:09 AM
Rutcutter's Avatar
Rutcutter
Be sure and get the TSB # when you take it in.
Old Mar 18, 2011 | 11:26 AM
Sgt93's Avatar
Sgt93
TSB# 11-3-23 I believe.
Old Mar 18, 2011 | 11:34 AM
Byram's Avatar
Byram
If anyone can - When at the dealer or something get this TSB and scan and post it here??
IT would be helpful.. Sound like a lot of us have some tranny issues that maybe would need to be addressed if in fact there is a trans fix with the above TSB..
Thanks - if anyone can...
Old Mar 18, 2011 | 12:25 PM
frt2599's Avatar
frt2599
Just got off the phone with the Ford dealer and had them run an oasis on my VIN. There is a just released TSB 11-3-23 for Super Duties built on or before 3/14/2011 (mine was built in November 2010) for several CEL's (P4020, P4021, and others) PLUS shift issues between 2nd and 3rd gear. He said something about another shift issue but didnt' get what he was saying as they were being as cooperative as a turd. Anyway I have an appointment to have it done on Monday. Hope this is the one that fixes it.
Old Mar 18, 2011 | 12:30 PM
Biggziff's Avatar
Biggziff
FORD: 2011 F-250, F-350, F-450, F-550
This article supersedes TSB 10-23-9 to add additional calibration content.
ISSUE:
Some 2011 F-Super Duty vehicles equipped with a 6.7L engine and built on or before 3/14/2011 may exhibit malfunction indicator light (MIL) on with diagnostic trouble codes (DTC's) P0401, P0402, P009A if driven at highway speeds with a snow plow attached, P164A if idled for extended periods in colder ambient temperatures, 2-3 transmission shift flares, harsh/inconsistent transmission shifting during transmission fluid warm up and tip-in events when at low speeds or coming to a stop. Refer to the Calibration Content for additional details.
ACTION:
Follow the Service Procedure to correct the concern
SERVICE PROCEDURE
Reprogram the powertrain control module (PCM) and the transmission control module (TCM) to the latest calibration using IDS release 71.05 and higher or 72.01 and higher. This new calibration is not included in the VCM 2011.3 DVD.
The Calibration Update Contains Improvement Actions And Enhancements:
DTC P0401 (exhaust gas recirculation (EGR) flow insufficient detected)
DTC P0402 (exhaust gas recirculation (EGR) flow excessive detected)
DTC P009A (intake air temperature/ambient air temperature correlation) if driven at highway speeds with a snow plow attached
False DTC P164A (O2 sensor positive current trim circuit performance (bank 1, sensor 1)) if idled for extended periods in colder ambient temperature
Harsh/inconsistent transmission shifting during transmission fluid warm up
Improved shift feel for tip-in events when at low speed or coming to a stop
Previously Released Calibration Content
Previously released calibration content included in IDS software release 69.07 and higher contained improvement actions and enhancements to address the following:
Calibration Content Vehicles Built On Or Before 11/5/2010
Delayed manual upshifts from 1st to 2nd gear when in Select Shift mode while going down a grade
Harsh/delayed 1-2 upshift and downshift
Harsh 2-3 upshift on first drive away of day after vehicle soak
DEF warning messages won't reset after refilling DEF tank with Key On Engine Running
Modified vehicles for rail applications, that will not re-engage PTO operation or speedometer inoperative after riding on the tracks with the front wheels off the ground
VSOUT signal inoperable from customer access circuits under dash
DTC P2463 or P246C (DPF restriction) and DTC P2459 (DPF regeneration frequency) - adds increased ability to perform manual regeneration at higher load values when performing system diagnostics
Calibration Content - Vehicles Built On Or Before 08/23/2010
False DTC P132B (turbocharger/supercharger boost control A performance)
False DTC P0299 (turbocharger/supercharger A under-boost condition)
False DTC P050E (cold start engine exhaust temperature too low)
False DTC P06EA (NOX sensor processor performance (bank 1, sensor 1)
DTC P249C (SCR time to closed loop) - improved diagnostics and reporting
DTC P249F (excessive time to enter closed loop DPF regeneration control) - improved diagnostics and reporting
False DTC P0884 (PCM/TCM power input signal intermittent)
DTC(s) and freeze frame data being erased in the PCM when running KOEO, KOER, Datalogger, Active Commands or any other guided diagnostics with IDS
False P0731 (gear 1 incorrect ratio)
False P0732 (gear 2 incorrect ratio)
False P0733 (gear 3 incorrect ratio)
False P0734 (gear 4 incorrect ratio)
False P0735 (gear 5 incorrect ratio)
False P0729 (gear 6 incorrect ratio)
Low speed/load engine surge
Abrupt engine shutdown feel
HP fuel pump knocking noise at idle
Delayed DEF level indication after refill event
Harsh/bumpy transmission upshifts/downshifts
Delayed/harsh transmission engagement feel between R-D and D-R shifts
Transmission gear hunting during speed control operation when climbing grades or climbing hills, particularly while towing
Erratic transmission operation after descending grades while in 1st gear
Flashes/delays of current gear indication when using SelectShift mode
Added Brake Over Accelerator (BOA) feature - reduces engine power during off-idle driving when both the accelerator and brake pedals are applied simultaneously
Added SelectShift memory feature, so SelectShift gear display comes back on whenever going back into drive if the vehicle was turned off while SelectShift mode was still activated
Added engine protection feature from overspeed while descending long grades while towing and in manual gear ranges (forces transmission upshifts at 4000 RPM)
Increased torque - during hill assist operation - (see Owner Guide for additional system operation)
PTO operational enhancements - (applicable to vehicles equipped with optional PTO)
- Automatic secondary electronic idle controller (SEIC) turns on at engine start if the switch in on position
- Engine coolant temperature to operate PTO lowered to -7 °C (+20 °F)
- Improved RPM control with SEIC controllers
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
110323A 2011 F-Super Duty 6.7L: Check DTCs, Reprogram The PCM And TCM (Do Not Use With Any Other Labor Operations) 0.6 Hr.
Old Mar 18, 2011 | 01:34 PM
Byram's Avatar
Byram
Thanks Guys - I need to check & see if they have release something for the Gasser... as that one appears to be only for the 6.7..
Old Mar 18, 2011 | 01:53 PM
frt2599's Avatar
frt2599
Just call your dealer and have them run an oasis on your VIN. That would tell you...
Old Mar 21, 2011 | 10:52 AM
Onsight's Avatar
Onsight
Just talked to my dealer and he said that TSB# 11-3-23 is outdated and unavailable.
Old Mar 21, 2011 | 11:23 AM
Sgt93's Avatar
Sgt93
What!?!? I need to call mine right now.
Old Mar 21, 2011 | 12:38 PM
Trueride's Avatar
Trueride
I just had mine at the dealer this past week for some minor work and ask about this update, they ran my vin and found no updates were available
Old Mar 21, 2011 | 02:40 PM
W7PSK's Avatar
W7PSK
Veteran: Navy
Just called my dealer, I have 2000 miles on mine.
He told me to keep driving it and let the computer learn my style.
I have hard shifting 3 - 4 and the Rev shift issue.
he said drive 2 - 3k more then he will do the update if its still an issue.
That bugs me
