door tag decode
Old Mar 16, 2011 | 06:42 PM
63 dump's Avatar
63 dump
door tag decode
I need a door tag decoded there seems to be some people here that can do that and I need to fix the transmittion and would like to know what trans is in it the numbers on door are
156 L F753 81A J HF8
23000 167 3800 74
It is a 63 F700 dump truck
Old Mar 16, 2011 | 08:20 PM
Jetcopterpilot's Avatar
Jetcopterpilot
23000 167 3800 74
First question is it stock with no engine or trans swaps? Or are you sure? The ID number is useless if the trans has been swapped as so many trucks of this age have at some point in time! You are better served to read the castng numbers on the trans, that way you are sure what it is! My ID numbers showed a 292 Y block with a 3 speed auto, and my truck has 352 with a 4 speed manual.... It would be a sjame to buy parts based on one trans only to pull it and find another! Casting Numbers are on the side of the trans, on some models it is on the passenger side, on others it is the driver side, get those numbers, then you will have half of the battle complete!
Old Mar 16, 2011 | 08:45 PM
63 dump's Avatar
63 dump
swap
I bought it from somewone who had it for the last 20 years and it basically sat only has 34000 miles on it has lots of rust issues but runs like a dream I am sure all is stock I just wanted to make sure I have a book on trans before I pull it and would be nice to know what axles, trans, etc I could know about it from factory.the numbers on trans are 224716
Thanks
Old Mar 16, 2011 | 10:06 PM
garbz2's Avatar
garbz2
23000 167 3800 74
156 is wheelbase
L Holly Green
F753 23,000 GVRW 2 1/2 ton nominal
81A Conventional Gas standard cab
J 5 speed Clark 250-V Direct
HF8 Recheck for typo H8 is a 2 speed split 7.17/9.77 18.5M There is no F8 code or HF,
23,000 is the maximum allowable weight
167 is the certified net horsepower
3800 is where the maximum HP is produced
74 Seattle Washington This is the District Office the truck was ordered from.
Post the VIN and it will tell what engine was in it when built.
Jetdude, post your info, and i will decipher it.
Garbz
Old Mar 25, 2011 | 02:35 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Three digit AXLE code: The first two digits refer to the rear axle, the 3rd digit to the front axle.
There is no HF rear axle code and the front axle code of 8 wasn't used until 1970.
It cannot be an F700 with a MODEL code of F753 which decodes to an F750 w/a 24,000 lb. GVWR.
Note: Compare the VIN or the Warranty Plate (if located on the left door face below the latch) with the VIN on the registration to see if they match.
People replaced damaged left doors with used doors. 99.9% of the time, they did not install the original Warranty Plate on the replaced door.
btw: Where will y'all decode the casting number found on the trans case? Casting numbers cannot be cross referenced to Ford part numbers.
ID engineering numbers can be crossed over, but these usually have a prefix, basic part number and suffix...like C3TA-7004-AA. I could not find the case # of 224716 listed anywhere.
Edit: This is prolly a Clark related number. The Ford/Clark ID tag was originally bolted to the six bolt PTO cover, located on the right (passenger) side of the transmission case.
Old Mar 25, 2011 | 03:12 PM
Jetcopterpilot
Thanks
The trans number sounds like a GM / Allison trans number!
yozsi
Jan 9, 2017 02:20 PM
hello113
Oct 29, 2016 11:37 AM
S.earl869
Jun 29, 2016 11:05 PM
eriksf250
Jul 22, 2014 12:37 PM
johnboy427
May 22, 2009 10:19 PM
