All I know this has been covered multiple times, but I need a little help.
Found allegedly new rear springs on craigslist. Stamped with Ford logo, labeled:
ZC34LC
RPN 1379
Craigslist owner said rear springs are from a 2006 truck that was sold (so no door codes to check). The springs were removed when new, to install a lift kit. What code would this be? I cannot find the prefix designation on any of the spring charts given on previous spring code threads.
My rear springs are sagging, and I would like to upgrade, I am hoping these are B-codes, so I can lift my X's bottom up again
Vinny, you may want to get the seller to measure the springs width and compare that to your stock springs width, I think at some point (possibily in '05 when the Superduty fronts went to coils) the F series rear springs got wider. I don't believe the new wide ones will work on our trucks. Hopefully someone will chime in if I'm off on the year of the change.
Thanks Tom for the help. I will measure my springs and then give the seller a call.
