C6 problem - swap??
Old Mar 16, 2003 | 08:29 AM
msautry's Avatar
msautry
C6 problem - swap??
Well, the C6 in my 89 Bronco is on its last legs it appears. I've got low and second, and sometimes it has Drive. Pulled the pan and there's some metal in it, so it's definitely time for a rebuild.
I also have an 82 "project" Bronco with a small block and a C6.
The big question is will the 82 trans go into the 89 with no problems? I fugure that'll keep me on the road while I get the 89 rebuilt.
Any help would be greatly appreciated.
Thanks
msautry
89 Bronco XLT
Old Mar 16, 2003 | 11:36 AM
GeneStoner's Avatar
GeneStoner
C6 problem - swap??
Do you have the same engine in both rigs? If so, then yes it'll fit. You just can't mix a bigblock engine with a smallblock bellhousing.
