Installation instructions for dp tuner
Old Mar 15, 2011 | 06:48 PM
Jessef250's Avatar
Jessef250
I just got my f8 and unhooked the batteries, cleaned the ECM, plugged it in and ran for few min died and won't start.. Any ideas? Ses light is on also.
Unplug and everything is ok.
Old Mar 15, 2011 | 06:56 PM
Kyle_KleinSS's Avatar
Kyle_KleinSS
Need to scan it for the codes. Did you clean the contacts well enough? Did the chip come loose and fall out of the pcm or did you tape it in?
Old Mar 15, 2011 | 07:02 PM
zx250's Avatar
zx250
Of the next Riffraff East
Rememeber to take the keys out while you mess with it, I know you had the batteries unhooked the first time, but it's easy to forget it the second or third time. Like he said, make sure it's seated good and in place. Make sure all your other connections are good and you have the switch in the right place.
Old Mar 15, 2011 | 07:03 PM
zx250's Avatar
zx250
If the switch is unplugged or comes loose, it will shut you down.
Old Mar 15, 2011 | 07:24 PM
Ponyboychris's Avatar
Ponyboychris
If you unplug the chip from the PCM and it runs fine, you either have to: 1) recheck/clean the connections on the PCM where the chip plugs in, 2) make sure you didn't overscrub the tin off the connections, or 3) check the connection into the back of the switcher. That would be where the usual problems lie.
Old Mar 15, 2011 | 07:48 PM
Jessef250's Avatar
Jessef250
Come to findout it wasn't plugged into the chip... Unhooked batteries, installed and works just fine now! Thank y'all! I really appreciate it!
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
