Carburator help
Old Mar 15, 2011 | 04:31 PM
uncleguns's Avatar
uncleguns
Carburator help
i just rebuilt my holley 2300, its on a 67 with a 360 in it. i was wondering if you could help me get it started again. i just cranks but doesent seem to be getting fuel. ive never rebuilt a carb before so i dont really know what i should be looking for.
Old Mar 15, 2011 | 04:42 PM
FLN's Avatar
FLN
it takes a minute or two for fuel to fill the bowl. Work your lever back and forth while looking down the top of carb. You should see fuel squirting each time you push the throttle.Another quick check is to disconnect fuel line at carb, turn it over and watch for gas from he fuel line. Dont forget to remove plug wire from coil first.
Old Mar 15, 2011 | 07:03 PM
tmcalavy's Avatar
tmcalavy
catch the gas with the hose in a jar/can...the accelerator pump should squirt gas each time you press the throttle when lookin down the bore. hope you put all the carb parts back in.
Old Mar 16, 2011 | 04:48 PM
uncleguns's Avatar
uncleguns
ok, it didnt work last night, but this morning i filled the fuel bowl up and put it together everything seems to work. it squirts fuel when i push on the accelerator pump arm
KOMBILOVE
Mar 8, 2016 09:15 PM
kadrocker
Feb 21, 2016 11:46 AM
moneypit79
18
May 3, 2015 04:52 AM
parkerparkerm
Nov 24, 2013 12:03 AM
Technitom
Nov 2, 2011 10:20 AM
