1978 - 1996 Big Bronco
oil problems
Old Mar 15, 2011 | 01:06 PM
superboy54's Avatar
superboy54
oil problems
I have a 78 bronco with a 400 engine. The problem started yesterday when i noticed the oil gauge needle go up high. Its still in the normal range but in the top part. When im driving it stays up high and after awhile when im coming to a stop it goes down, then when i completely stop it goes down to the middle. What can be the problem. I would really appreciate any advice.
Old Mar 15, 2011 | 01:21 PM
StuntmanFyke's Avatar
StuntmanFyke
how long since your last oil change, what weight of oil are you running, and what kind of temps weather wise?
Old Mar 15, 2011 | 01:58 PM
Kemicalburns's Avatar
Kemicalburns
also look into installing a mechanical pressure gauge. this way you know exactly what the pressure is.
Old Mar 16, 2011 | 05:42 PM
superboy54's Avatar
superboy54
About 3 months on my last oil change and i used 40 oil. I live out here in el paso so its getting pretty hot weather. On the mechanical gauge what is suppose to be the readings.
Old Mar 17, 2011 | 12:21 AM
StuntmanFyke
I always go by 10psi vs every 1000rpm you should be good as a bare minimum
Old Mar 17, 2011 | 10:44 AM
Kemicalburns
what oil filter are you using?
