Changing out front shocks, how difficult?
Old Mar 15, 2011 | 08:43 AM
Billyclub's Avatar
Billyclub
They need to be replaced and I want to do it myself. Do I need any special tools?
Old Mar 15, 2011 | 08:50 AM
cj45lc's Avatar
cj45lc
No special tools & not very difficult. Pass side I got the nuts off the top through the wheel well.
Old Mar 15, 2011 | 09:00 AM
Billyclub's Avatar
Billyclub
When I had the bed off last year I replaced the rears. I know alot of people like the Bilsteins but I don't want to spen big bucks if not needed. I went with NAPA premiums on the rear. What would you folks recommend other than the Bilsteins
Old Mar 15, 2011 | 09:10 AM
Night Crawler's Avatar
Night Crawler
Rancho, Pro Comp. I wouldn't put a NAPA anything on my truck, I used to, but get kinda tired of doing things 2-3 times cause of cheap parts. I did a brake job 2yrs ago, rotors,calipers, pads. rotors are warped and calipers look worse then the stock ones.
Old Mar 15, 2011 | 09:11 AM
rebelmdb's Avatar
rebelmdb
They are a 12 pack job. It takes 5 min to change them. After that sit in the shop and drink your beer you don't want people to know its actually easy to work on the Fords.
Old Mar 15, 2011 | 09:12 AM
jwhitetail's Avatar
jwhitetail
Its more work getting the wheels off then putting shocks on. Pro Comp,Rancho,Skyjacker are some other's.
Old Mar 15, 2011 | 09:47 AM
cj45lc's Avatar
cj45lc
I put the monroe reflex on mine & I didn't take the wheels off
Old Mar 15, 2011 | 10:12 AM
timmyboy76's Avatar
timmyboy76
i put pro-comps on too, along with not removing the tires. Unfortuntly, after month and a 1/2, had to replace the rears, just blew right out, how..not sure, and not to stoked right now. Hope'n they "fix' this issue. Might wanna hold onto the stockers, just for a bit.
Old Mar 15, 2011 | 10:19 AM
Rose Clifford's Avatar
Rose Clifford
warranty those things, get some freebies. those could have been defects
Old Mar 15, 2011 | 10:49 AM
cgl's Avatar
cgl
I went with the BDS 9500 series for my 02, Mainly because my off road guy says they're the best for what I do, and the fronts were easier to replace then the rears IMHO. 5 minute job for sure.
Old Mar 15, 2011 | 10:55 AM
big poppa's Avatar
big poppa
If you don't mind the color difference the Monroes have been around awhile, got them on my wifes Expy now, good riding shock. Very easy to put on like everybody mentioned, hook the top shock to the tower and get the bolt ready when you cut the plastic shock retainer strap, as the shock is expanding down pop the bolt thru the lower hole, tighten up and your done.
Old Mar 15, 2011 | 03:02 PM
c125bob's Avatar
c125bob
I put Monroes on my truck and have been happy with them. Nothing to it just like everybody else said. I didn't take the tires off either. Just be ready to react when you cut the plastic tie. As the shock moves down, slide it onto the lower mount. Don't ask me how I know !!
Old Mar 15, 2011 | 06:53 PM
gtnwood's Avatar
gtnwood
Just put the Monroe Reflex on the fronts as well when I added the leveling kit and couldn't be happier, well actually I could but thats another story.
Old Mar 15, 2011 | 07:26 PM
Ponyboychris's Avatar
Ponyboychris
The hardest part is to break the nuts loose on the old shocks if they have some rust on them. PB Blaster should make short work of the nuts.
Old Mar 15, 2011 | 08:59 PM
onelionhunter's Avatar
onelionhunter
Fronts
I would spend the money on the fronts for good shocks, I had the best Napa sells on the front and they were blown at 25k miles in 18 months. The engine in these things is a boat anchor, 1000lbs dry, add in 8 gallons of coolant, 4 gallons of oil, etc, etc, the fron takes a serious beating.
Edit: You will need an 18mm socket which not all kits have, other than that, it requires nothing special.
edit Edit: Here is a good price on the Bilstiens for the front, with free shipping. Thats per shock http://www.shockwarehouse.com/site/p...ount-BOOT-down)
