Engine Code?
Old Mar 15, 2003 | 11:55 PM
Michael Strawn's Avatar
Michael Strawn
Engine Code?
1G140130
Would this block number be a 460 cid?
Old Mar 16, 2003 | 10:59 AM
airharley's Avatar
airharley
Engine Code?
engine block codes are just above the starter. or you can pull a code off of the intake manifold to identify what engine it belongs to.
Old Mar 17, 2003 | 08:11 AM
Just Strokin's Avatar
Just Strokin
Engine Code?
What you have listed there is a partial VIN number. For a numbers matching restoratio, it would be important.
I don't remember for sure, but the first digit represents the year and not sure what the Letteris for (might be the product line, if so, the G is Mercury Comet, Cyclone, Montego, etc).
Old Mar 17, 2003 | 04:15 PM
Michael Strawn
Engine Code?
Thanks to Airharley and Juststrokin for the replies.
Old Mar 17, 2003 | 11:09 PM
Mil1ion's Avatar
Mil1ion
Engine Code?
Then block casting numbers are on the passenger side of the block are just above the starter.
The heads casting number are just above the spark plugs & just below the bottom lip of the valve covers.
Inside the valve covers is the actual Date of casting code.
The Intake manifold casing numbers are just in font of the carb on the intake.
Look for marks like this
Old Mar 18, 2003 | 06:13 AM
Michael Strawn
Engine Code?
The casting number listed in the first post came from the intake manifold. We are trying to determine the displacement and year of the engine. Thanks for all of the help so far guys.
Old Mar 18, 2003 | 08:29 AM
georgedavila's Avatar
georgedavila
Engine Code?
All 429 and 460 blocks are the same stock bore. The casting number above the starter others have pointed you to will tell you what year the block was cast, actually what year the casting design was accepted for production. Only the casting number will tell you that. The VIN states year of production for the vehicle and what components it was originally equipped with.
Block casting numbers
C8XX-XXX - 1968
C9XX-XXX - 1969
DOXX-XXX - 1970
DIXX-XXX - 1971-1978.
Look on the crankshaft for a 2Y or 4Y stamping. That's usually on the front throw.
4Y - 429
2Y-XXX - 460, 1968-1978, internally balanced
3y-XXX - 460, 1979- externally balanced
