Overheating? After a long run
Old Mar 14, 2011 | 11:53 AM
Charlotte's Avatar
Charlotte
I drive an 88 Ranger, 2.9l Engine. A long time ago, a mechanic told me the temperature gauge indicator shouldn't get above the "R" in "Normal". However, these days I find if I drive over 20 k, it does get that high, then fluctuates back down again. Could it be a problem with the guage itself? I'm also noticing the fuel gauge now tells me there is much more gas in it than there actually is.
No steam comes out of the truck and it doesn't go into the red. If it is a potential problem, I'd like to deal with it before it gets worse.
I've checked the top hose and it's hot, which indicates the thermastat opens properly. I've checked the rad and other hoses and they also feel hot after a drive. If there is a problem, would changing the coolant fix it, or could it be something else?
Thanks,
Charlotte
Old Mar 14, 2011 | 03:05 PM
Beechkid's Avatar
Beechkid
Time to replace the thermostat
Old Mar 14, 2011 | 05:09 PM
justforkicks's Avatar
justforkicks
My 91 is the same way. Fluctuates between the R and A?
Old Mar 14, 2011 | 05:18 PM
aquanaut20's Avatar
aquanaut20
Put an IR gun to it and determine the correct temp... Philip
Old Mar 15, 2011 | 12:07 AM
Charlotte's Avatar
Charlotte
Question
What's an IR gun? Are they cheap to buy and how do you use one?
Old Mar 15, 2011 | 08:46 AM
03 Maz B23's Avatar
03 Maz B23
IR gun is an Infrared gun. Point at object you want to check temp on and it reads it. Harbor Freight, car parts stores and hardware stores should have at reasonable price.
Old Mar 15, 2011 | 10:42 AM
Beechkid's Avatar
Beechkid
What also works well is a "meat" thermometer...but it does have to be placed in the fluid reservior.
Old Mar 15, 2011 | 10:47 AM
grandmas77f150's Avatar
grandmas77f150
Replacing the coolant couldn't hurt either
Old Mar 17, 2011 | 07:38 PM
Charlotte's Avatar
Charlotte
The problem has been fixed! No thermastat or coolant flush needed, just a brand new radiator cap. Took the truck for a long drive today and the temperature was completely normal. However, I will still be doing the rad flush, since preventative measures are the best repairs made for future problems.
Cheers,
Charlotte
carconnoisseur
New Member Introductions
Jan 29, 2016 09:57 AM
70Bumpside
Jan 8, 2016 01:39 PM
mikefred44
Jun 1, 2015 10:10 AM
auto doug
WTB - Parts & other
Oct 30, 2014 09:32 AM
Charlotte
Jan 15, 2010 04:24 AM
