Sponsored by: Real Truck
Power window issues
Old Mar 13, 2011 | 05:58 PM
Alex-H's Avatar
Alex-H
Power window issues
Not a major problem just real annoying.
So the drivers window won't open, when I push the button it kinda budges a little bit but thats it. The passenger window will only go down slighty and then has difficulty going back up. Any thoughts on this?
Thanks in advance guys.<!-- / message -->
<!-- controls -->
Old Mar 13, 2011 | 06:24 PM
7.3 Ex's Avatar
7.3 Ex
I've had this problem come and pass without doing anything. I think it is a weak motor needing to be replaced. The fact that it does at least move makes me less suspicious of a relay or switch. Spraying silicone lubricant down the sides into the window channels is supposed to help if you are able to get it open again. My front passenger window is extremely slow and in the cold will often stop, especially on the way up. I have had a new motor for a couple years just need to find time to install but I expect that will cure the dragging window problem.
Old Mar 13, 2011 | 07:08 PM
RCKYMTN-PSD's Avatar
RCKYMTN-PSD
Two windows not moving properly - problem started at the same time? I would start with the switch.
Old Mar 14, 2011 | 09:27 AM
Alex-H's Avatar
Alex-H
I'm not sure when it started because I just bought it and its had the issue. I was thinking the motors but I'm not sure.
Old Mar 14, 2011 | 11:45 AM
Trucky2's Avatar
Trucky2
I'd see if you can work one down with a little help and then get some silicone lube in the tracks. Mine seemed to get a bit sticky in the snows and ice and road salt. A quick dab of slippery stuff cured em.
Old Mar 14, 2011 | 12:41 PM
Alex-H's Avatar
Alex-H
Alright I will try this when I get a chance, what kind of silicone lube should I use? Thanks for the help, I found myself ashing my cigar out the rear slider last night. haha
Old Mar 14, 2011 | 12:44 PM
Trucky2's Avatar
Trucky2
I just used some generic silicone lube in a tube, used for pulling wire. It's about the consistency of vaseline and almost impossible to wash off but cheap and effective.
Old Mar 14, 2011 | 01:03 PM
MachDream's Avatar
MachDream
I just finished fixing this same exact problem on mine. Down in the door jamb on the drivers side is a rubber boot that covers the wires going into the door...peel that rubber boot back (be agressive) to expose the wires. look for a break/wires showing on the black wire and possibly the white. When i found mine the black wire was completely broke and the white wire was frayed. fixed the wires with some solder and shrink sleeve and all windows are fast and work perfect up and down.
Old Mar 14, 2011 | 11:17 PM
7.3 Ex's Avatar
7.3 Ex
The silicone I use is in a regular metal spray can like spray paint rattle cans or rust penetrators. Don't remember if it had a straw. I also spray it on all of the weatherstripping just to keep it all healthy and water resistant. Maybe the thicker goopy stuff would be more effective but with the spray can I'm able to shoot it down the sides of the window channels. You can find this stuff at any AutoZone or NAPA, just ask for spray on silicone.
I'm curious MachDream, had your windows stopped all together or just slowed? You've got me curious about taking a peak to look for broken wires. None of my windows have ever been fast.
Old Mar 15, 2011 | 08:23 AM
MachDream's Avatar
MachDream
seven3,
My situation was my windows would roll half way up or down sometimes, all the way sometimes, 1/4 etc, etc. After swapping in new relays and a known good master window switch off my buddys truck to test....i realized something; when the drivers door was wide open (wires in the door jamb more in a strait line) windows worked fine. when i hopped in and shut the door (wires in the door jamb now kinked a little due to the angle) windows did not work. At that point i peeled the rubber boot back to expose the wires and there it was...almost broken black and alot of copper showing on the white.
Old Mar 17, 2011 | 11:36 AM
vdaiuto's Avatar
vdaiuto
my drivers side would go 1/2 way at normal then kinda stick. would have to hit the button a couple of times to make it go all the way down . now sometimes it would go all down then "stuck " there for a while before it goes back up..maybe i should check the wires too. are these wires easy to get o and fix and with what
Old Mar 17, 2011 | 11:52 AM
MachDream's Avatar
MachDream
youre issue sounds more like needing silicone on the window tracks, wouldnt hurt to check the wires tho to be safe. You should be able to "feel" (visually speaking) if it is getting "stuck" or if there is a short/broken wire. For me i knew it was a short because it was just off and on, not slow or anything. when they would roll it was fast, or not at all.
wreedZ71
2004 - 2008 F150
Jan 4, 2011 07:27 PM
youngdw
Aug 14, 2010 09:56 PM
cpetersen
22
Jun 29, 2010 09:54 PM
yambag
Apr 7, 2010 01:44 PM
