Salvageable Carpet?
Old Mar 13, 2011 | 03:48 PM
bigdavesohc's Avatar
bigdavesohc
Salvageable Carpet?
Today I ripped out thhe interior of my truck to assess the damage done to the floorboards, and I was originally going to replace the carpet. However, the carpet is in really good shape except for a few oil/grease stains. I would like to clean and reuse it, but only if the stains are removeable. Any suggestions?
BTW, where's the best place to get two new floorbaords?
Old Mar 13, 2011 | 04:06 PM
CalebJns's Avatar
CalebJns
Rent you a carpet cleaner from the grocery store or home depot or lowes...
Old Mar 14, 2011 | 04:53 AM
Kalve's Avatar
Kalve
check bout getting some carpet cleaner from a parts store or some greased lighting an use it an scrub it clean.
Old Mar 14, 2011 | 10:10 AM
78 PEB's Avatar
78 PEB
X2 on what the above posters said. You may also consider dyeing it, RIT dye works.
Old Mar 14, 2011 | 02:08 PM
Ziegelsteinfaust's Avatar
Ziegelsteinfaust
Also simple green or dish soap and a scrub brush
Old Mar 14, 2011 | 04:46 PM
jjski78's Avatar
jjski78
^Professional detailer
Get some Castrol Super Clean, and a pair of rubber gloves, and a stiff nylon bristle brush. Wet down the carpet, spray on cleaner, put on gloves, and scrub. Rinse, repeat until the stains are sufficiently gone.
Or you could go out and buy a hot water extractor, but the cheapest one will run you over $600 easy.
Old Mar 14, 2011 | 04:57 PM
CalebJns's Avatar
CalebJns
If you don't feel comfortable doing it, call your local ServiceMaster, or carpet cleaning company, and have them quote you...they can also scotch guard it...
