Turbo boost ?
Old Mar 13, 2011 | 12:45 PM
Pitcrw6's Avatar
Pitcrw6
Turbo boost ?
When I drove from South Carolina to Eglin AFB Florida last week I did 70 MPH the whole way and RPM's were @ 1900 - 2000 and my turbo boost was between 1 1/2 to 2 pounds of boost, is this normal for that speed or should I not have any boost at all till I go higher in speed. How much does the wastegate play a part? I have a Banks Big Head wastegate installed. Im still learning and trying to understand it all.
Old Mar 13, 2011 | 05:15 PM
trike1946's Avatar
trike1946
Don't have a good answer for you but I will bump you back up.
Old Mar 13, 2011 | 05:25 PM
woodnthings's Avatar
woodnthings
At that speed I usually see more like 5 lbs of boost. But i suppose it could be the difference in the mods I have versus the ones you have.
Old Mar 13, 2011 | 05:46 PM
JT250's Avatar
JT250
I usually saw 5-8 in my stock tune, but I have my red tube pulled and plugged going to the waste gate and I tightened my actuator rod. I would think that is low. You probably have a boost leak or your rod is too loose. Then again I dont know much about the banks, but when I asked a vendor about it he said you can just tighten your rod and get the same affect.
Old Mar 13, 2011 | 05:52 PM
JOHN2001's Avatar
JOHN2001
Thats what I see in my truck most of the time at those speeds. Thats also empty
Old Mar 13, 2011 | 06:09 PM
Pitcrw6's Avatar
Pitcrw6
I also had about 500 lbs in the bed. I will ck for any boost leaks and maybe tightend the act rod up 1 or 2 turns and go from there.
Old Mar 13, 2011 | 06:15 PM
JOHN2001's Avatar
JOHN2001
When you put the bighead on didnt you tighten it up 7 turns already?
Old Mar 13, 2011 | 07:10 PM
Pitcrw6's Avatar
Pitcrw6
I went by the instructions that came with it, not sure how many turns it told me too turn it. I know I put it on the correct way I must have read those instructions at least 25 times when I installed it just so I wouldnt screw anything up.
