Help installing new rotors
Old Mar 12, 2011 | 09:36 PM
mustanginca's Avatar
mustanginca
93 F250 with dana 50 TTB. Got the original rotors seperated from the hubs. I'm using an impact gun to pull the new rotors on to the hub. One side pulled completely tight rotor to hub no wiggle room. Now I have used the impact as much as it will give (350 ft lbs) and it still has very little play around the whole hub. I'd say 1/16th of an inch. Can I leave it like this and install it? or should I try something else? Thanks.
Old Mar 14, 2011 | 12:20 AM
rla2005's Avatar
rla2005
There should not be any "play" in the hub to rotor mount. Something is wrong, IMHO.
Old Mar 14, 2011 | 12:24 AM
mustanginca
That's what I figured. I bolted it all back up. I have to take them off to get turned so I'll try and fix it then. Thanks.
brcwelding
Mar 28, 2012 03:45 PM
TheBlueMule
Mar 11, 2010 11:39 AM
Eric K
Apr 24, 2007 04:36 PM
tom2131968
1978 - 1996 Big Bronco
Aug 14, 2006 11:21 AM
Mistro
Jul 29, 2002 06:08 AM
