460 won't roll
Old Mar 12, 2011 | 02:52 PM
ThatOneGuy's Avatar
ThatOneGuy
460 won't roll
So I needed to do some suspension work so I yanked the 460 out that has 3600 miles on rebuilt. It went straight to a stand where it sat for a year covered and the only work done was I painted it. I drained the oil about about 6 months ago to pivot it on the stand. I put the engine back in last weekend and went to roll the crank to bolt up the converter and it will not budge... I took it back out to check alignment and all was good, still will not budge. Any ideas? I'm a complete noob when come to engines and everyone I talk to say say "Hmmmm never heard of this after just a year" It ran when I took it out (backed it into the shop) Hoping for a easy fix cause I can't afford for someone to tear it down again, word I keep getting is put some type of lube in the cyl and be patient but I want to wait to see if any of you all experienced this? Thanks in advance for the info.
Old Mar 12, 2011 | 09:55 PM
wyoming4x4's Avatar
wyoming4x4
pull spark plugs.
If engine will not roll? If moisture in cylinder and caused rings to stick add some marvel mystery oil per cylinder and should free up cylinder. Also once engine oil back in engine could prime oil with a drill and get oil throughout engine in critical spots. Have to pull distributor and rig up tool to turn oilpump shaft to do this. But believe the engine has froze up rings to cylinder. marvel mystery oil and let set for a day or so and hopefully free up engine. good luck!
Old Mar 12, 2011 | 11:45 PM
ThatOneGuy's Avatar
ThatOneGuy
Sounds good.....will get some tomorrow and give it a shot...So how much Marvels do I put in there? TY
Old Mar 28, 2011 | 02:13 AM
Moto Mel's Avatar
Moto Mel
I would put 1 ounce per cylinder through the spark plug holes. After letting it sit for a day try rocking the crank using the dampner bolt and a long breaker bar or cheater both ways, just a little at a time til it rotates evenly with the plugs out.
Old Mar 28, 2011 | 09:02 AM
mark a.'s Avatar
mark a.
Is the truck is a auto ? If it is were you sure the converter was in all the way ?
Old Mar 30, 2011 | 01:16 AM
Moto Mel's Avatar
Moto Mel
That is a very important question. He didn't mention not being able to bolt the engine and bell housing together though. Usually they won't go all the way to the block if the converter is not fully seated in the pump. I have seen more than a few busted bells because someone tried to force the assembly.
Old Apr 2, 2011 | 08:11 AM
ThatOneGuy's Avatar
ThatOneGuy
The tranny is an auto and it it is all bolted up to the bell housing, all four studs are sticking through fly wheel.
It is moving now,.....slowly and only a little at a time, but its working, thanks for all the info.
