Shifting Question/Problem
Old Mar 22, 2011 | 08:40 PM
  #31
whack&stack's Avatar
whack&stack
Originally Posted by Mark Kovalsky
Codes that are set are stored in the PCM's memory for about a month after the last time the error was present.
so it could be throwing codes that arent set and wont read unless i am driving it and it shifts incorrectly. is that correct?
Old Mar 23, 2011 | 06:41 PM
  #32
fordpride's Avatar
fordpride
If I had the truck I could plug in a scan tool, go for a ride, and tell you what's happening. My guess is that it isn't shifting to overdrive, which is 4th gear.
What he's talking about is useing the scan tool to see what the PCM see
Old Mar 23, 2011 | 06:42 PM
  #33
fordpride's Avatar
fordpride
if your OD light was/is flashing then you should have a code
What scan tool did you put hook to it not all will read our trucks
Old Mar 23, 2011 | 06:53 PM
  #34
whack&stack
the od light was never flashing. one of my buddies at the ford dealer plugged in the scanner he is a diesel mechanic there so i am assuming he used the correct scanner
Old Mar 23, 2011 | 06:58 PM
  #35
fordpride's Avatar
fordpride
Have you looked at the VSS abd tried to clean it
RDockery
Apr 21, 2016 08:50 PM
TheJoblin
1983 - 2012 Ranger & B-Series
Oct 22, 2015 09:41 PM
Mikemusial
Sep 17, 2014 09:43 PM
Chris.Brame
1997 - 2003 F150
May 20, 2011 09:04 AM
2020
Mar 9, 2009 04:13 AM
