DSII HEI ignition
Welcome to Instant Rimshot
Heat sinks are those finned pieces of aluminum that passively dissipate heat from (usually) solid state electronics.
His system, using the GM 4 pin module, gives you (what is the name of that high dollar aftermarket dizzy?) one of those for next to nothing.
I put an 84 460 into a 93 chassis and have removed the ECC and really don't want to mess with this DSII conversion with the 2 pos wires and resistors and relays. I have the DSII dist and coil on the motor and want simply. Will this link Better Dirt Cheap Electronic Ignition work straight forward with my setup. This is a work Dump truck with 4.10 and 4 speed so power and torque are what I am looking for.
I'm putting a Duraspark dist. in the 73 in my signature, but I can't for the life of me find a DSII box or harness in my local junkyard. I was thinking about using the GM 4pin and mounting it in the cab up under the dash. I hope you guys don't mind helping me understand and tolerating a couple questions. Most of the GM 4pin install threads here on FTE degrade into bickering and personal attacks, but this thread is different. You guys really seem to know what you are talking about, so I hope you can help!
I found a great article HERE (direct .doc download) explaining the inner workings of the HEI module. It is absolutely a must-read.
In the image above, it appears that the coil and the module would be getting full 12v form the ignition switch. This matches the article that says:
While looking for stock GM HEI coil info, I found this:
Sorry for the long post, I'm just trying to make sure I understand exactly what I'm doing. If you guys have the info, could you post up your coil primary resistance, what voltage you are seeing at the coil, and how long you have been running this way?
But, I am feeding the full 12V current to 3 X GM HEI's and 3 X MSD blaster 2 (8202) coils on my rotary. All 6 are powered from a single relay, triggered by the original ignition power wire.
The only issue I've ever had was all 3 HEI's failed almost simultainiously, due to excessive heat. The guy that I got the car from used a piece of 22 ga sheet metal to mount the HEI's. I replaced that with a piece of 3/16" stainless and artic silver 5 CPU paste, and upgraded to a better brand HEI.
The MSD coils on mine appear to have the same 0.7 ohm primary resistance, according to the specs I've found online.
All I can say is this, the ignition system can certainly handle trips to well over 7K RPM........
Warning: rotary question
What is the duty cycle for each module in your rotary application? I don't have the brain-brain today to even begin to try to figure that out... With the v8 and a single coil, 4000rpm / 2 / 60sec X 8cyl and I'm looking at 266.6 spark events per second (unless my math is FUBAR.) Not a whole lot of time for dwell! How often does a rotary use each module per second?
The rotary fires all 4 plugs (2 per rotor) every rotation of the shaft, however, the way I have mine rigged up, 2 of those plugs fire every 1/2 rotation, for 2 per rev, but those 2 plugs have their own HEI and coil. The other 2 plugs share a HEI/coil, and are run thru the stock dizzy to separate the fire.
At 6000 RPM, each coil fires 12,000 times/minute or 200 times/second. The exact same number of cycles/second as a standard 4 cyl at any given RPM, and only 1/2 of the cycles as a V8 at the same RPM. (note, the 4 cyl and V8 comparison assumes a single coil setup)
As you can see, 8000 RPM on a rotary isn't asking the coil or HEI to do any more work than 4000 RPM on a V8. I just have 3 of each, but only 2 magnetic pickups to trigger them. 1 pickup triggers 2 HEI/coil combos, and those coils are hooked directly to the plugs, 1 coil, 1 wire, 1 plug. This gives me 3 sparks per rev, per rotor.
It sounds super complex, but it's really pretty simple. Complex comes with trying to explain how a 600 CFM isn't "too big" for an 80 CID (1.3L) engine...... In fact, it's borderline too small. Rotary VE can exceed 125%, even in non-boosted form. Prolly has something to do with no valves stopping/starting the flow of air. When 1 rotor face has finished drawing air, the next starts drawing instantly, so the velocity remains at peak levels.
Interesting little critters, with only 3 moving parts....... And 30 tiny metal pieces to take the place of piston rings, each with their own spring, any one of which can really ruin your whole week, and engine....... And bank account......
