1989 ford bronco full size 5.0 AOD trans 44 front and 8.8 rear floor shift 4X4 blah blah blah
i noticed today after hitting a million billion pot holes (midwest people are use to it) my front end passenger side is lower then the drivers side. the only thing i could really tell was a good 1.5" difference from the top of the tire to the trim on the fender.
since the bronco has 4 shocks on the front end, is it ok to just buy 2 heavy duty shocks to replace all 4 on the front end?
well the spring in the front end is not broken, i did notice one of the shocks is oily on the top meaning it is depressurizing.
is it ok to only have 1 shock on each side of the truck's front end? (its expensive even for a carquest employee to buy all 4 shocks for the front end)
x2 on the Bilsteins. If you're going to go with only 2, make sure you do the rear pair as they are the main shocks, the forward pair are the auxiliaries. It should ride a little better with only one set, the auxiliaries were part of the towing package usually.
The forward shocks are the auxiliary set on trucks equipped with the quad setup. You can run with just the aft set in place and be no different than a standard equipped Bronco/F-150.
