2 piece drive shaft questions
I'm driving a 1994 f350 CC long box 4x4 with the E4OD. I finally found a 5 speed for it and I'm sure I can find a donor truck with the clutch peddle, ect. My questions are:
Is there a specific clutch system for the 7.5/ZF5 combo?
Do I have to replace both of my rear drive shafts or just one?
Thanks guys!
Thanks guys!
The clutch release components may be shared with the diesel version, but I don't know for sure. The 7.5 clutch release is for sure different than the small block version.
If the rear driveshaft is like the one on my '87, it will be the same from the carrier bearing to the axle, and different from the carrier bearing to the transmission. I don't know if this will hold true for your F350 or not.
