cam
Old Mar 14, 2003 | 11:14 PM
metallicafan's Avatar
metallicafan
cam
hi everyone, i have a 1990 f-250 with a 300 inline 6, i want some more power and was thinking of puttin in a cam. heres the detales of it http://www.cranecams.com/truck/503905.htm, is this gonna work with my stock efi???
Old Mar 15, 2003 | 09:32 AM
windsorizer's Avatar
windsorizer
cam
If you have Mass air flow, GO FOR IT. With MAF, the engine provides fuel based on how much air is coming into the engine. Since the cam will allow more "flow", the sensor will pick this up, and compensate for it. However, i would try and find a performance MAF sensor before you install this cam. If you find one, you can be assured that even if the stock MAF sensor can't handle it, your aftermarket one will. Good luck!!
Old Mar 15, 2003 | 10:26 AM
chuckman's Avatar
chuckman
cam
he said it was a 90, so no MAF for him. however, that cam should be mild enough to work with the stock speed density system. just make sure to use new lifters and springs when you throw that thing in.
