EOP switch on 2003
Old Mar 9, 2011 | 08:55 PM
cheezit's Avatar
cheezit
Originally Posted by m-chan68
GUILTY
man that makes me feel better...
I had the nickname bp for about a week last time.
Old Mar 9, 2011 | 09:08 PM
m-chan68's Avatar
m-chan68
When I was a little green with working on 6.0Ls years back, I remember installing the drain tube incorrectly. THAT made a HUGE mess. Thankfully, the F*** UP FAIRY hasn't bit me in years, when working on these things.
Old Mar 10, 2011 | 05:40 AM
TheBestKindOfEX's Avatar
TheBestKindOfEX
EOP switch thread size......?
IIRC a 27mm deep but Im not sure. they dont fail that often. If the sender doesnt fix your issue be sure to post back up and I can offer some more direction.
Hey Cheezit and PatMac6.0....do you know what thread size the EOP sender is?
I am going to install an EOP sender for a gauge and wanted to Tee off of that point. I wanted to get the parts together before I disassemble.
The 6.0 Bible shows a test port on the front of the oil cooler but I can't even see it under all the other stuff over it, so I was going with the other spot for ease of install.
Thanks
Old Mar 10, 2011 | 06:52 AM
npccpartsman's Avatar
npccpartsman
Thanks
It's a 7/16-20 bolt thread. That's why it's o-ringed. It might be difficult to find an adapter to screw into that hole without manufacturing one or retapping the hole to pipe thread.
Old Mar 10, 2011 | 07:06 AM
TheBestKindOfEX
Originally Posted by CLPF350
I've posted my solution to Ford's oil pressure gauge before but it may be helpful to do it again. I removed the Ford pressure sender, it was an NPT thread, 1/4" if I remember correctly. I used an adaptor and a length of 300 psi hydraulic hose to reach over to the passenger side battery area where there is some room to work. I used a "T" threaded to the hose to accommodate the Ford sender and a Westberg oil pressure sender and gauge installed in an "A" pillar pod. I had to extend the wire to reach the new location for the Ford sender. I used a 1/2" all thread rod secured to the battery tray to mount the "T". Oil pressure is 60psi @ road speeds, 20 psi at hot idle and pegged at cold start up.
Hmmm.....new issues. Now I'm totally cornfuzed. So npccpartsman what size is the test port on the oil cooler? Might have to go that route.
Old Mar 10, 2011 | 07:13 AM
npccpartsman
I don't know about the test port as I don't have one anymore since I have the bulletproof block. I do know about the sending unit because I had to measure it for someone else and just checked my old one to verify. You might do a little searching or wait for some more comments. There have been lots of different ways this has been done.
Old Mar 10, 2011 | 05:23 PM
cheezit's Avatar
cheezit
that port on the front of the engine is a STORM fitting.
Old Mar 10, 2011 | 05:56 PM
TheBestKindOfEX
I'm not the 'brightest bulb'.....what is a STORM fitting? I tried googling it and all I got was some drainage pipe stuff.....
Old Mar 10, 2011 | 06:14 PM
cheezit's Avatar
cheezit
man thats been a long time for the exact definiton. I dont remember anymore then what its called. lmao. it does unscrew though. and also sealed with an oring
Old Mar 10, 2011 | 06:49 PM
TheBestKindOfEX
Have you ever connected a test gauge to it? is it not at all like the test port on the fuel filter housing that we connect fuel pressure senders to? Sounds to me like I'm gonna have to crank up the lathe and make some adapters.....
The picture in the 6.0 bible looks like that test port has a plastic cover over it like it is a quick connect fitting. Maybe kinda like an air hose quick connect ? Does that sound rediculous?
Old Mar 10, 2011 | 06:53 PM
cheezit's Avatar
cheezit
infact I have. I have the fitting to hook on to it in my box. its a harvester thing. I thisnk its also used to fill the oil in the system durring prodution. or at least that was what I was told.
Old Mar 10, 2011 | 09:09 PM
TheBestKindOfEX
Can you post a pic of it or am I taking this too far....just curious
I think I found it......
Ford Motorcraft 303-765 High Pressure Pump Test Adapter
It looks like the adapter for the fuel pressure test port. Maybe it's the same M12 size.
Last edited by TheBestKindOfEX; Mar 11, 2011 at 04:38 AM. Reason: added link to HPOP test adapter, added last line below link
Old Mar 10, 2011 | 09:19 PM
  #28
william_04_x's Avatar
william_04_x
I've met her many times, but didn't know her name until now.
Old Mar 11, 2011 | 04:47 PM
  #29
cheezit's Avatar
cheezit
no it looks different. it maybe the same thread pitch that screws in to the housing. the storm fitting that hooks up to it looks like an air chuck fitting.
Old Mar 11, 2011 | 06:34 PM
  #30
PatMac6.0's Avatar
PatMac6.0
dude just finished replacing the eop switch, that was the simplest job in the world after that metal hose was removed..... your the man! thanks for the help!!!
