WELDERS PAY ATTENTION!!!!!
Old Mar 15, 2011 | 08:27 AM
tjc transport's Avatar
tjc transport
i ain't rite
another thing for the novice welder to remember is that welding galvanized steel is almost as deadly as using brake cleaner and welding.
when you weld galvanized, the smoke contains toxic gasses.
to weld galvanized, you first need to clean the zinc coating off completely with a grinder, and then when you weld it, it is recommended to have a fan behind you to blow the smoke away from you.
Old Mar 15, 2011 | 10:35 AM
drjoe171's Avatar
drjoe171
Originally Posted by CJM8515
FYI this refers to chlorinated brake cleen, not the other type. The chlorinated type comes in a green can and the other in the red.
I still wouldnt use it.
Isn't the phos warning on the red can in the article/picture?
Should be in HuGe letters on the Front of the can!
D8chumley
2009 - 2014 F150
44
Sep 22, 2013 08:38 AM
D8chumley
Feb 27, 2010 02:29 PM
D8chumley
Dec 25, 2008 09:39 AM
