1978 - 1996 Big Bronco
tranfering the tranny
Old Mar 9, 2011 | 05:19 AM
jetjr1865's Avatar
jetjr1865
ok i have a 90 bronco,5.0 efi 4x4 w an aod trans.my trans just isnt cooperating ,,Soo,i want to know if i got one from the auto recycler ,if i pulled one say from a crown vic will it go on my transfer case if i just pull off the tail piece or do i have to take parts from the bad tranny
Old Mar 9, 2011 | 09:33 AM
Kemicalburns's Avatar
Kemicalburns
are you positive you have an AOD. do you have an Overdrive button either on the dash or on the end of the shifter?
if you do have an AOD you probably need to get the tv cable adjusted. when was the last time you serviced your tranny?
I would not get an AOD out of a car. and any AOD prior to 87 was garbage and strewn with issues.
Old Mar 9, 2011 | 09:48 AM
jetjr1865's Avatar
jetjr1865
did you even read the whole ?
Old Mar 9, 2011 | 11:39 AM
b4hntn's Avatar
b4hntn
We are all trying to help but need some more information. What if your transmission just needs a little help? Like Kem, who is one of the best, provide more facts please and you may not have to swap.
Old Mar 9, 2011 | 11:43 AM
StuntmanFyke's Avatar
StuntmanFyke
Reading the whole ? is irrelevant with his suggestion. Why replace the whole thing if all you need to do is adjust the tv cable? As far as your question, no you can't just take the tail shaft off and bolt up a tcase. In order to to do what your saying you have to tear the entire tranny down, which at that point why not just get one made for a 4x4?
Old Mar 9, 2011 | 12:14 PM
Kemicalburns
the AOD stopped being mass produced for the bronco after 89. you can go find an AOD out of a 4wd and swap it in there but my guess is you dont even have an AOD thats why i asked those questions. installing the incorrect tranny in there will cause some issues in so many ways.
try answering my questions, Help us help you. remember you came to us.
