Rear spring hanger HELP!!!!
Old Mar 8, 2011 | 09:13 PM
rangermike's Avatar
rangermike
Hey guys, I am replacing the rear spring hangers on my 96 F250 and I did grind all the rivets flat like everyone said and they seem to be stuck! I cant get them out. I have tried hammering them out with hammer and punch, hitting the hanger from all angles with a BFH and a little heat. Not working. Anyone have some advice? Any help would be awesome! Thanks guys, Mike
Old Mar 8, 2011 | 09:27 PM
ri_truck_guy's Avatar
ri_truck_guy
What are you heating them with? If its just propane, you may need to move to something with a little more kick like MAP gas or acetylene.
Old Mar 8, 2011 | 09:30 PM
frederic's Avatar
frederic
After I ground off the rivet heads mine were stuck also, so I ground the tip of an air chisel, shoved it at the edge of the seam against the frame, and pulled the trigger.
It took a while to get started, but after a few minutes they popped off.
There's a lot of surface area between the frame and the brackets, so the rust has some strenght to it.
Old Mar 8, 2011 | 09:54 PM
rangermike's Avatar
rangermike
I was just using mapp gas with a hand torch. I tried chiseling the rivets out but not between the frame and hanger. I will try that next. I have to be carefull with heat and what not cause its right by the side tank and some fuel lines.
bigf350sd
1947 and Older Ford Trucks
Jun 20, 2012 06:20 AM
79 f-150 guy
30
Jun 25, 2010 01:22 PM
CatBob
Jun 29, 2008 01:31 PM
stewards68
Dec 17, 2006 08:58 AM
