Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1964 Firetruck! VIN Locations? I'm new.
Old 03-08-2011, 07:56 PM
Louisiana's Avatar
Louisiana
Louisiana is offline
I should have joined long ago but we sometimes do things to help our friends that we don't get around to doing for ourselves, so my first question is about this; My friend just bought a 1964 firetruck and needs the actual vin to get it titled. Problem is that back during it's tour of duty a brick wall fell on it and all those years ago the cab or most of it was replaced. He told me it appeared to be a 700 or 750 series truck, so I am tentatively assuming it is a F750.
Question; How many places did Ford put the VIN in '64 and where are they ?
I'm hoping it is on the frame somewhere.
Thanks guys,
Your friend, Louisiana
Old 03-08-2011, 10:07 PM
Louisiana's Avatar
Louisiana
'64 F750 VIN Locations - I'm still researching.
Old 03-09-2011, 09:54 AM
awhtx's Avatar
awhtx
awhtx is offline
Check the top right side of the frame between the radiator panel and the firewall.
Old 03-09-2011, 10:16 AM
80broncoman's Avatar
80broncoman
80broncoman is offline
Im sure it is stamped on the frame....somewhere??
And have you guys looked at the drivers door?? isn't there a alum warrenty plate riveted to the door? (near the latch)
Old 03-09-2011, 06:45 PM
Louisiana's Avatar
Louisiana
Thanks guys ! We will be checking for those numbers now that we know where to look.
You guys are great ! Maybe someday I can return the favor. Your friend, Louisiana
Old 03-11-2011, 06:03 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
The Warranty Plate could be located on the left door face below the latch, or on the inside of the glove box door.
However, if the plate is on the door, compare the VIN on the Warranty Plate with the VIN on the registration to see if they match.
People replaced damaged left doors with used doors. 99.9% of the time, they did not install the original Warranty Plate on the replaced door.
Hidden VIN location: Top of the right (passenger) side frame rail-either partially under the cab, or just in front of it. It's prolly covered up with rust and road grime, so it will be hard to read.
The VIN has 11 digits: First 3 is the SERIES code (example: F75 = F750), the 4th digit is the ENGINE code, the 5th is the ASSEMBLY PLANT code.
The last 6 digits is the Numerical Sequence of Assembly, the trucks specific serial number and decodes to the year.
dcyachtdoctor
01-04-2020 11:09 AM
wpnaes
S. California Chapter
50
07-31-2016 08:59 PM
ditto1958
New Member Introductions
09-20-2014 04:01 PM
Jaxfiretruck
17
07-22-2011 12:13 AM
fishmanndotcom
03-14-2011 01:01 PM
Quick Reply: 1964 Firetruck! VIN Locations? I'm new.
