1978 - 1996 Big Bronco
ECM identification?
Old Dec 25, 2008 | 12:33 AM
mickey_bigdaddy's Avatar
mickey_bigdaddy
When typing part numbers, disable the smilie text.
I don't understand what you are referring to.
Old Dec 25, 2008 | 12:43 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
FTE member dro man wondered why the smilie showed up when he typed that long list of part numbers.
When typing part numbers that have an 8 and D together, if the smilie function isn't disabled, you get this:
When typing a post, scroll down to see: Additional options.
Old Dec 25, 2008 | 12:46 AM
mickey_bigdaddy
When typing certain part numbers that have an 8 and D together, if the smilie function isn't disabled, you get this:
Ahhhh, I see. Got it.
Old Dec 25, 2008 | 06:36 AM
dro man's Avatar
dro man
The PCM and HEC will need to be hooked to Ford software (IDS) and a parameter reset preformed to enable a restart.
99-2001 Mustang PCM’s are compatible, but as for as a 2003 with 99, not sure which type system it (2003) uses. (Type C or Type E)
99-01 uses type C
Old Dec 25, 2008 | 02:47 PM
mickey_bigdaddy
Can you explain the HEC? Where is it? What does it look like?
Old Dec 25, 2008 | 05:41 PM
dro man's Avatar
dro man
HEC
Hybrid Electronic Cluster
It is a microprocessor, an integral part of the cluster that communicates, links, talks, with the PCM.
The PCM has to receive a valid / programmed key signal from the Hec before it (PCM) will allow a fuel pulse and on some models starter interrupt. The transceiver, mounted around the key, sends a signal to the HEC , the HEC then sends, multiplexes, a valid key code on the network to the PCM, circuits 914 and 915 the twisted pair of wires.
Old Feb 6, 2009 | 06:35 AM
searcherrr's Avatar
searcherrr
Question
Droman - I'm in desperate need of help. I've been troubleshooting a poor fuel economy problem on a NEW engine with mostly NEW parts including the PCM for 16 months now.
I hope you are still there!
My VIN is: 2FMDA5149SBB05565 - 1995 Ford Windstar 3.8L SFI
Basically I need to know what the original part # was. Let me know if you need anything else. THANKS A MILL !
Old Apr 12, 2012 | 08:49 PM
Bad_Bronco_Guy's Avatar
Bad_Bronco_Guy
Help Dro Man
I too have an ECM issue. I read that if I post the numbers off the door of my Bronco II you can tell me the right ECM for the rig so here goes......
1FMCU145GUA66876 - This is a 1986 Frod Bronco II with the 2.9l V6
Thanks for the help!
Old Feb 3, 2015 | 02:39 PM
plbiggs's Avatar
plbiggs
ECM
I have a 1988 Ford F150 and need the ECM part number, I have been struggling to get it out. The sticker on the door was gone when I bought the truck but the VIN is 1FTEX14H5JKA35775. Have been having some idling issues, surging at a stop, thinking it is the ecm - when I try to find a replacement there are so many. Called a ford dealership and they said it was too old to run the VIN and give me the numbers, this is my only vehicle trying to get it running good again.
Old Apr 6, 2016 | 06:52 PM
Rufus Rodriguez's Avatar
Rufus Rodriguez
Ecm question.
Originally Posted by dro man
post your calibration # off the door or VIN and i can supply your orignal pcm part number
Would you be able to give me the ECM part # for my 1987 F150 with my vin #?
I bought a nice 1987 f150 4x4 efi 4 speed stepside to restore and I noticed the ecm is not the correct one.
Old Apr 6, 2016 | 08:41 PM
Rufus Rodriguez
Ecm question.
Old Apr 6, 2016 | 08:44 PM
Rufus Rodriguez
Ford vin #
Vin # is. 1FTEF14N6HKA24092
Old Apr 7, 2016 | 07:17 AM
  #28
rla2005's Avatar
rla2005
How do you know it's not the correct ECM? What is in there now?
Old Jul 19, 2018 | 06:49 AM
  #29
ZJgrandcherokee's Avatar
ZJgrandcherokee
Pcm numbers
Hey if I give you a vin # can you tell me what my oem pcm numbers would be?
Old Nov 25, 2018 | 04:29 PM
  #30
Hermione Gingold's Avatar
Hermione Gingold
89 F250 VIN 1FTHF26HXKNA44359 My truck has an ECM #E8TF-12A650-AT1B and I am not sure it's the correct one. Anybody know how to look it up?
