my trucks in the the shop it's been missfiring and lackin power all the coils are good new plugs and boots and still missfiring there are now checking for shorts in the wiring and it's either the wiring or the computer
the truck 2002 f250 4x4 5.4 gas 6speed stick
how much is the computer
where is the computer in the truck
Reason: forgot somthing
it runs but its missfiring and lacking power
so if the trucks starts and runs the pcm is ok then
cause i know the mechines that are workin on her and got to see what there dianosti coumpter said while the trucks was runing said the pcm thinks its ok to run off 7 cycinders and its not showing any codes
all the coils are workin we tested all the coils the new pcm is comin in on monday have the truck back tuesday we also tested all the wirering to the pcm thinks 7cylinders is ok to run off
