77 400 alternator mounting
Old Mar 8, 2011 | 02:00 PM
RJR99SS's Avatar
RJR99SS
I've had the alternator off my 77 for so long, i dont even remember how it goes back on.
Does anyone happen to have any pics of how it is mounted?
Old Mar 8, 2011 | 02:27 PM
ibleedblue1385's Avatar
ibleedblue1385
The top bolt goes into the corner of your head, while the bottom one will swing in and out(for adjustment) on another bracket.
I will try and find a picture....
Old Mar 8, 2011 | 02:28 PM
704 dentside man's Avatar
704 dentside man
Two long and skinny bolts should hold the bracket and go into the water pump. The thicker long bolt goes through the the bracket, through the alt's top eyelet, and there should be a nylon spacer between the alt and the block that the thick bolt goes through, then the bolt threads into the block. Then the bottom eyelet should go in front of the bottom bracket, and the small bolt should go through the bracket and thread in to the alt.
Remember to keep everything relatively loose, so things have the opportunity to move or shift if they need to. Also, don't forget to hook up the wires to the back side of the alt before you install.
Old Mar 8, 2011 | 02:29 PM
ibleedblue1385
Here you can see the top portion of the alternator:
Feb 19, 2012 08:48 AM
HillbillyDeluxe81
Jan 15, 2010 05:32 PM
4x41977
Jan 18, 2008 07:44 PM
olewilly
Electrical Systems/Wiring
Feb 3, 2007 03:45 PM
