1978 - 1996 Big Bronco
Help
Old Mar 8, 2011 | 12:20 PM
smokeyisthebandit's Avatar
smokeyisthebandit
Help
I have a 89 full size bronco with a 4.9 litre 6, I was driving down the road and it died acted like I was out of fuel.I replaced fuel filter and checked fuel pump.and my rig still won't start where should I go from here ? plz.help
Old Mar 8, 2011 | 12:22 PM
frenchy107's Avatar
frenchy107
there might an inertia switch that shuts the fuel pump off. look into that.
Old Mar 8, 2011 | 01:04 PM
smokeyisthebandit
fuel pump is working fine
fuel pump is working and got plenty of fuel pressure
Old Mar 8, 2011 | 01:33 PM
Kemicalburns's Avatar
Kemicalburns
couple things to check.
unhook the coil cable. take off the distributor cap and have someone turn the motor over, becarful of the fan. this is to make sure the rotor is turning. next would be making sure your getting spark from the coil and the plugs are getting spark.
when was the bronco tuned up last? start with the basics and think simple first.
Old Mar 8, 2011 | 05:46 PM
vtjvt's Avatar
vtjvt
My 90 with a 5.8 did the same thing last year. It ended up being the module on the side of the distributer.
Old Mar 8, 2011 | 11:23 PM
greystreak92's Avatar
greystreak92
PIP - (Profile Ignition Pickup) and if so, your 89 will tell you that as soon as you run a KOEO test on it.
Old Mar 9, 2011 | 05:59 AM
b4hntn's Avatar
b4hntn
I agree with the possibility of PIP if it died like you turned the key off. If you are getting PIP codes in continuous memory suspect either the ICM module or the pickup in the distributor if your wires, plugs, cap and rotor are good. Both may rear their ugly heads when warm. After a couple of rebuilt distributors I finally used a press and installed Motorcraft hall effect sensor. I suspect the rebuilders do no test them warm.
After pulling codes disassemble and clean grounds by the battery and by the diagnostic test connector and see if it starts.
js2743
Jun 23, 2023 12:36 PM
tacomacream
1983 - 2012 Ranger & B-Series
Jul 16, 2016 05:56 PM
rcfreed
Jun 26, 2015 01:20 AM
Stevenmcm
Jun 16, 2013 04:37 PM
realteacher54
Jun 15, 2011 10:04 PM
