surging and choking
Old Dec 31, 2002 | 06:19 PM
Red_mud's Avatar
Red_mud
surging and choking
Whe you installed the TPS did you adjust it so that it had 1 volt with just Ing switch on.
Old Dec 31, 2002 | 10:27 PM
91FordBaja's Avatar
91FordBaja
surging and choking
Red Mud, I'm not sure What your talking about. I'm not sure I understand, can you explain in lamens terms? Maybe please? It would sure help me out. Thank you for your support
ME
Old Jan 1, 2003 | 12:27 PM
Red_mud's Avatar
Red_mud
surging and choking
You should have grey/red wire and grey/white wire on the the back side of the TPS connector harness. Remove the throtle body. With the switch off, insert stright pins down beside these two wires, connect a volt meter to the stright pins, neg side to grey/red and pos to the grey/white, turn the switch on . Loosen the TPS screws and rotate it untill you have a reading of 1 volt. This is how the Haynes Manual says the TPS should be set up. I had to do this a while back after installing a new TPS. You may have to play with the stright pins to get a good connection. Hope this helps!!
