Any Thoughts?
Old Mar 7, 2011 | 09:59 PM
specialK4464's Avatar
specialK4464
Any Thoughts?
So im sure this is a pretty well beaten topic but i have yet to find some info im in need of. I have an 05 6.o and its 2wd. Im not really too fond of the way it sits up front, so im thinking about a leveling kit. The only things ive found for a 2wd are 2 inch kits. Is there any company or place that sells anything bigger? I would like to get more but im assuming theres a reason im only finding 2 inch kits. Any thoughts and/or opinions will be very helpful. Thanks in advance.
Old Mar 7, 2011 | 10:05 PM
mhoefer's Avatar
mhoefer
2 inches will lift the front, so it will be level with the back. You can go this way, or you can use a higher weight rated spring if there is one available. Front coil springs van get soft, new springs might be a good solution for 2 wheel drive.
Old Mar 7, 2011 | 10:11 PM
specialK4464
with the stiffer springs could you also do the 2 inch kit? and also are the stiffer springs going to stiffen up the ride? it just seems to me that 2 inches wont level the truck. from level ground to the center of the wheel well arc, the measurements are 4 inches apart.
Old Mar 7, 2011 | 10:13 PM
Ian123's Avatar
Ian123
ive seen 6 inch lifts for 2wd trucks. Heres a pic of one...
Old Mar 7, 2011 | 10:16 PM
specialK4464
THATS what im looking for. Do you know where a guy might get one like that? and if it will require other parts besides the lift itself?
Michael Pace
Jul 7, 2013 08:47 PM
lilsmokey
Jun 26, 2012 11:48 PM
Shwan_89HD
92
Jan 13, 2012 10:43 PM
NASTseventhree
Mar 11, 2011 10:25 PM
19Camper72
Jun 5, 2006 12:29 AM
