Noises from dashboard.
Old Mar 7, 2011 | 09:40 PM
BigBlue92's Avatar
BigBlue92
I've been hearing this noise coming from somewhere in the dashboard of my 1997 F250 HD. It sounds like water splashing back and forth. It doesn't happen all the time. Just wonderin what's causing it.
Old Mar 7, 2011 | 09:55 PM
zxwut?'s Avatar
zxwut?
I don't have a clue except to say maybe check the cowl and see if there's some trash in there that's clogged it up. Maybe it's holding water?
Old Mar 7, 2011 | 10:55 PM
drjoe171's Avatar
drjoe171
Try turning off your heater control valve.
Mine sounds like 'running' water when it's on.
I've tried to bleed the air out 100x so I just pretend I'm on a tropical beach and try to not let it put me to sleep.
Old Mar 7, 2011 | 10:59 PM
zxwut?'s Avatar
zxwut?
Your idea makes much more sense than mine. I forgot that if you get air in there, the heater does make some noise.
Old Mar 7, 2011 | 11:12 PM
drjoe171's Avatar
drjoe171
How are things in Afghanistan?
My daughter just went thru there and said some of the food is reallyreally good.
Old Mar 7, 2011 | 11:26 PM
zxwut?'s Avatar
zxwut?
Where did she go through? I can't think of anywhere in Afghanistan that has good food. We're usually on the verge of running out of the disgusting crap they send us lol
Old Mar 8, 2011 | 12:41 AM
86F150302's Avatar
86F150302
Its water running through the heater core. Mine does it every now and then. Make sure your coolant level is good.
Old Mar 8, 2011 | 02:41 AM
Webasto 9.1KW's Avatar
Webasto 9.1KW
My dash is squeeking from time to time. I figure the truck is just "talking" a little bit so I squeek back to it. Only when I´m alone in it though... :retard
Old Mar 8, 2011 | 03:42 AM
TexasGuy001's Avatar
TexasGuy001
I'll also agree with the heater core making sounds. I have never seen a truck from our generation that had a valve on it.
Webasto. As for you dash squeeking, take a look at the passenger side lower dash by the kickpanel. There is a plastic tab that is common to break.
Old Mar 8, 2011 | 09:31 AM
BigBlue92's Avatar
BigBlue92
My coolant level is good and the heat works great. Will water running through the heater core cause damage? If so, how do I fix it?
Old Mar 8, 2011 | 09:53 AM
zxwut?'s Avatar
zxwut?
The point is to have water running through the heater core. That's what does the heating.
Old Mar 8, 2011 | 03:26 PM
drjoe171's Avatar
drjoe171
A couple things that may work ...or not.
A 3 dollar 'flush n' fill' kit has a 'T' fitting that goes in the heater hose line.
And it sure looks to be the highest point in the system. and seems reasonable to bleed the air out.
Park the truck as uphill as you can so the rad fill is as high as possible.
Push down on the heater hoses so they are lower than the rad fill,
Make sure the heater temp valve is all the way open.
I asked this question a few weeks ago and got at least a full page of this as a common prob/issue and most everyone just gave up and live with the sound.
If your rad cap shows full a few times when cold or takes 1/2 a coffee cup of water a few times when cold, there's really not much else to do.
One guy filled his by taking the top rad hose off and another filled his cooling system thru the top heater core hose
F100 AMG
WTB - Parts & other
Aug 31, 2014 10:29 AM
Lenster
Dec 16, 2013 06:43 PM
brookst45
1997 - 2003 F150
Apr 11, 2007 09:26 PM
