break lights
Old Mar 7, 2011 | 08:11 PM
ragphoto's Avatar
ragphoto
break lights
my break lights stopped working. i installed a new turn signal assembly and everything was working great. today i discovered my break lights arte not working. no blown fuses and i made sure all the connections in the turn signal assembly were connected. the hazards work, the turn signals work... any ideas???
Old Mar 7, 2011 | 10:04 PM
Ziegelsteinfaust's Avatar
Ziegelsteinfaust
On my 66 there are 2 wires coming off the master cylinder. All you have to do is connect them to see if the lights coming on. Sometimes those things can go out.
Old Mar 8, 2011 | 04:34 AM
ragphoto's Avatar
ragphoto
I could be wrong and will check but I dont thing there are any wires from my master cylinder? Should there be? I have a 69 F100.
Old Mar 8, 2011 | 05:09 AM
Talltruck's Avatar
Talltruck
No, your truck's brake lights work from a switch that's mounted on the brake pedal up under the dash. It's a pretty simple deal, make sure it has power coming to it. Possible that the switch is bad given you've replaced most everything else.
Old Mar 8, 2011 | 05:18 AM
ragphoto's Avatar
ragphoto
is this what your talking about
1969 Ford F-100 Pickup - Brake Light Fail Switch | FordParts.com
I did replace the master cylinder as well. I must have missed that somehow???
Old Mar 8, 2011 | 06:53 AM
ragphoto's Avatar
ragphoto
It was the switch on the pedal... Thanks...
BigCountry1978
15
Sep 3, 2025 08:33 AM
SeaCarr
All Things Towing
Aug 8, 2016 03:43 PM
whaase
Jun 16, 2015 09:32 PM
jrf250
Mar 12, 2014 08:20 PM
