Spark plug gap
Old Mar 7, 2011 | 01:37 PM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
Spark plug gap
Whats the largest spark plug gap you can run on a OEM ford ignition system?
would .05 be okay. I believe the plugs are spec'd at .044, but im wanting to add a little power and fuel efficancy if it was possible. Also goin to advance the timing to 14 BTDC as long as the motor allows it.
Thanks
Old Mar 7, 2011 | 02:36 PM
jas88's Avatar
jas88
Most Ford coils that I have experienced will fire a .050 gap without issue. A wider gap is good for firing lean mixtures, but if it is too much, you will misfire under load, because the spark is not strong enough to fire the richer mixture.
Oh, I see you are running a 5.4L, I have not tried a wider gap on a COP motor. I have always set those to spec.
Old Mar 7, 2011 | 03:03 PM
BURNSTOUGHFORD
Ehh im not messing with that truck. The truck im talking about is a 351w. hence i posted in this forum.
Shernius
1997 - 2003 F150
17
Apr 1, 2015 09:05 AM
bigcrunch
Dec 5, 2009 05:05 PM
riverdog
Jul 24, 2007 11:20 AM
EXPLORER GUY
Dec 1, 2006 10:49 AM
ssKable
Mar 5, 2005 12:46 PM
