fuel level sender
Old Mar 6, 2011 | 06:25 PM
Triggh4's Avatar
Triggh4
fuel level sender
Ok iv got a 75 ranger that only has the aft axle gas tank now. Fella I bought the truck off of put Auto Meter Sport-Comp gauges in it but for some reason never put a fuel gauges in it. Now I have found a same series gauge, but im not sure if it will work cause ill need there fuel level sender.
I need to know if this fuel level sender will fit in my rear tank or if the origenal will work. Or if yall know what ohm the stock fuel sender runs on. Or heck any ideas at all would be nice. thanks
Auto Meter
Auto Meter
Old Mar 6, 2011 | 06:35 PM
bucks77ford's Avatar
bucks77ford
I don't think that universal sender will work because the original senders use a lock ring to secure them while that aftermarket is a bolt down type. The correct ford Ohm sender would be 75-10 Ohms. I couldn't find the sport comp gauge, but there is the sport comp II gauge that will work with the original ford sender to make things much easier.
Auto Meter 3615 - Auto Meter Sport-Comp II Analog Gauges - Overview - SummitRacing.com
Old Mar 6, 2011 | 06:57 PM
Triggh4's Avatar
Triggh4
thank you for your help, this has been a pain for awhile now.
Old Mar 6, 2011 | 07:03 PM
bucks77ford
Glad to help out. It's better to stay with an original Ford sender so if you have problems you can ask and diagnose better than with aftermarket universal stuff.
Old Mar 6, 2011 | 07:05 PM
Triggh4's Avatar
Triggh4
Auto Meter
this one is 73-10 ohms will this be a issue. I could not find one that matched up 75-10ohms
Old Mar 6, 2011 | 07:57 PM
bucks77ford
That'll work. I've seen different descriptions from 73-10ohms and 75-10 ohms.
Old Mar 6, 2011 | 08:13 PM
Triggh4's Avatar
Triggh4
Ok i appreciate it. By the way thats a nice lookin truck ya got there.
