Sponsored by: Real Truck
cab leaking water
Old Mar 6, 2011 | 06:06 PM
CRACKERJOHN's Avatar
CRACKERJOHN
cab leaking water
my cab is separating at the seams below the rear window. about two inches long from the window seal down. the water is running into the channel just in under the trim panels between the doors and the carpet. any one else having this problem ??? I put some flowable silicone on it and stopped the leak but it won't last forever.
Old Mar 13, 2011 | 11:11 PM
digler's Avatar
digler
Ditto
My 01 has this two, don't know what caused the seem to separate, but was told to use polyurethane body seal to fix.
Old Mar 14, 2011 | 02:50 AM
cartmanea's Avatar
cartmanea
I don't think the seams are separating really, not structurally anyway. The spot welds are still intact, but the seam is then sealed with a body seal and that material is cracking, which then creates a crack in the paint an a place for water to get in. My '03 shows the crack, but I've never noticed any leak.
Old Apr 10, 2011 | 07:21 PM
CRACKERJOHN
thanks for the help, the silicone is still working for now
