high idle
Old Mar 6, 2011 | 12:46 PM
buffy.mike's Avatar
buffy.mike
high idle
1 have a 91 ford f150 it is idleing at 2000 rpm if i disconnect the idle control module it idles at 500 rpm i checked for air leaks ive taken off the throttle body hoses and hold my hand over the openings and the truck will die ive read on other post that this means no leaks ive put on a new idle control module cost 78.00 no change but cannot return electronic part has anybody got any ideas im lost
Old Mar 6, 2011 | 01:06 PM
rla2005's Avatar
rla2005
You should have looked here first and saved yourself $78: Ford Fuel Injection » How To Run a Self-Test
Old Mar 6, 2011 | 06:06 PM
buffy.mike's Avatar
buffy.mike
thank you very much
Old Mar 6, 2011 | 06:08 PM
dgoertel's Avatar
dgoertel
on there left side of your throttle body there is a rubber nipple make sure thats new an tight second the idle control modual is on the right side of it warm your engine up or drive it for about five minutes un plug the modual. before you unplug note where its idling if its around 2000 like you said un plug it it should drop down between 500- 900. wich is where it should be. An instead of buying that new wich had done you coulda unplugged it an tested it like this or drove like this the only difference is in the mornings or when you first start your truck it might wanta die at first. because you unplugged the iddle control. but rev it up just a little for like 20 seconds an she'll idle just fine.
