Sponsored by: Auxito
Won't Start
Old Mar 6, 2011 | 10:51 AM
TruckWontStart's Avatar
TruckWontStart
Won't Start
2001 V8 Triton auto trans. problem began last winter. As soon as the weather turned cold the engine would crank until the battery weakened but would not fire. Checked for spark, has spark..checked for fuel flow, getting fuel, hooked up DIY OBDII code retriever and it flashed through and read 'err' without showing a code. The anti theft is not an issue as the light performs as expected, flashes twice then goes out. Let the truck sit for the winter (lack of funds). Spring rolled around, replaced battery and vrooom, started up like nothing was ever wrong. Ran fine all spring and summer (drove it twice to Florida and back). This fall, the temp dropped and same issue all over again. I'm lost. Help.
Old Mar 6, 2011 | 11:09 AM
projectSHO89's Avatar
projectSHO89
Define your current condition, ie, "No crank", "Cranks but does not fire", etc.
Identify WHICH V8 engine, and the transmission (auto/manual).
Observe the MIL during bulb prove out. Does it come on with the rest of the cluster lamps?
Does the cigar lighter work?
Old Mar 6, 2011 | 12:10 PM
TruckWontStart
Won't Start
MIL? As for cluster of lights, they function as normal. Lighter also functions normally. As stated, everything works accordingly save the fact that it will crank until the battery cannot sustain it any longer...it just refuses to fire up.
Old Mar 6, 2011 | 08:00 PM
BlitZ_'s Avatar
BlitZ_
sounds like a common cold start injector problem. i had this problem on some older model fuel injected engines before. i replaced the injector and bam started up fine ever since.
Old Mar 7, 2011 | 06:58 AM
TruckWontStart
BlitZ! You are a flocking GENIUS! It makes a whole lot of sense given what the facts are. I'll let you know how it goes since I'll have to wait til the weekend to do the job. You've got to know though, that once I get it done and the bad boy fires up, I'll be doing the 'Young Frankenstien' bit in your honor..."IT'S ALIVE"
Instead of "Two heads are better than one" It should be "FORUM heads are better than one."
Thank you sir for your input.
banks0531
37
Sep 3, 2014 08:45 PM
chandrabites
Jun 20, 2014 04:36 PM
AeroGuy1212
Aerostar
Jun 20, 2011 01:11 AM
templarknight
Aug 29, 2010 06:26 PM
crothenberger
Aug 23, 2003 11:10 PM
